Acer Aspire 5253 RAM Replacement
  1. Acer Aspire 5253 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over.
  2. Acer Aspire 5253 RAM Replacement: step 2, image 1 of 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 RAM Replacement: step 3, image 1 of 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 RAM Replacement: step 4, image 1 of 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 RAM Replacement: step 5, image 1 of 1
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 RAM Replacement, Back Cover Panel: step 6, image 1 of 1
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 RAM Replacement: step 7, image 1 of 1
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 RAM Replacement: step 8, image 1 of 2 Acer Aspire 5253 RAM Replacement: step 8, image 2 of 2
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 RAM Replacement: step 9, image 1 of 1
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
  10. Acer Aspire 5253 RAM Replacement, RAM: step 10, image 1 of 1
    • Now, locate the RAM.
  11. Acer Aspire 5253 RAM Replacement: step 11, image 1 of 1
    • Locate the two metal pieces on both sides of the RAM that are holding it in place.
  12. Acer Aspire 5253 RAM Replacement: step 12, image 1 of 1
    • Pull the tabs apart to remove the RAM.
    • The RAM will pop up once they are pried open.
  13. Acer Aspire 5253 RAM Replacement: step 13, image 1 of 2 Acer Aspire 5253 RAM Replacement: step 13, image 2 of 2
    • Carefully slide the RAM out of the compartment.
6 other people completed this guide.
Cynthia Barajas
2,195 Reputation
5 Guides authored
Cal Poly, Team 8-11, Regan Spring 2014 Member of Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Members
15 Guides authored
One Comment
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
nhanblack1996 - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 3,851
