AT&T NVG510 Button Replacement
  1. AT&T NVG510 Button Replacement, Reset and Wi-Fi Buttons: step 1, image 1 of 1
    • Place the router on one side so that the rubber stands are facing upward.
    • Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
  2. AT&T NVG510 Button Replacement: step 2, image 1 of 1
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
  3. AT&T NVG510 Button Replacement: step 3, image 1 of 2 AT&T NVG510 Button Replacement: step 3, image 2 of 2
    • Pry open the case to reveal the board.
    • Some force may be required.
    • Take out the one screw located on the center-right area of the board.
  4. AT&T NVG510 Button Replacement: step 4, image 1 of 2 AT&T NVG510 Button Replacement: step 4, image 2 of 2
    • Lift the board slowly out of the case.
    • Be careful as to not damage the board.
  5. AT&T NVG510 Button Replacement: step 5, image 1 of 1
    • Locate the buttons to the right of the yellow ports along the edge of the board.
  6. AT&T NVG510 Button Replacement: step 6, image 1 of 3 AT&T NVG510 Button Replacement: step 6, image 2 of 3 AT&T NVG510 Button Replacement: step 6, image 3 of 3
    • Locate the silver points that connect the buttons to the board.
    • To release the buttons, use a soldering iron to heat up and melt the silver connecting points.
    • Avoid touching the solder to the board. Touch only the silver points.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 561
