Introduction
If your laptop does not read CD's or DVD's properly, there might be a problem with the optical drive. The following guide will help you replace the optical drive.
Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
Slide the optical drive out. It should easily come out.
What kind of connection links the dvd with the laptop? sata? Something else?
One Comment
On my Asus U57A you only have to remove the one 2mm screw under the plastic cover on the bottom and the optical drive slides right out. This seems like a considerable amount of overkill to me.
