ASUS U57A-BBL4 Motherboard Replacement
  1. ASUS U57A-BBL4 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Motherboard Replacement: step 2, image 1 of 1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Motherboard Replacement: step 3, image 1 of 1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Motherboard Replacement, Front Panel Assembly: step 4, image 1 of 2 ASUS U57A-BBL4 Motherboard Replacement, Front Panel Assembly: step 4, image 2 of 2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Motherboard Replacement: step 5, image 1 of 1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Motherboard Replacement: step 6, image 1 of 1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Motherboard Replacement: step 7, image 1 of 2 ASUS U57A-BBL4 Motherboard Replacement: step 7, image 2 of 2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Motherboard Replacement: step 8, image 1 of 2 ASUS U57A-BBL4 Motherboard Replacement: step 8, image 2 of 2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Motherboard Replacement: step 9, image 1 of 3 ASUS U57A-BBL4 Motherboard Replacement: step 9, image 2 of 3 ASUS U57A-BBL4 Motherboard Replacement: step 9, image 3 of 3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
  10. ASUS U57A-BBL4 Motherboard Replacement, Optical Drive: step 10, image 1 of 1
    • Slide the optical drive out. It should easily come out.
    What kind of connection links the dvd with the laptop? sata? Something else?
    Thomas Seiffert - Reply
  11. ASUS U57A-BBL4 Motherboard Replacement, Motherboard: step 11, image 1 of 1
    • Remove the four 2 mm Phillips head screws from the top of the motherboard and fan using PH #1 screwdriver.
  12. ASUS U57A-BBL4 Motherboard Replacement: step 12, image 1 of 2 ASUS U57A-BBL4 Motherboard Replacement: step 12, image 2 of 2
    • Remove the blue cable on the bottom right by lifting up on the tab and pulling the cable out.
  13. ASUS U57A-BBL4 Motherboard Replacement: step 13, image 1 of 3 ASUS U57A-BBL4 Motherboard Replacement: step 13, image 2 of 3 ASUS U57A-BBL4 Motherboard Replacement: step 13, image 3 of 3
    • Peel off the black and yellow tape attaching the fan to the base.
    • Peel the tape off the yellow cable and pull out to remove the cable.
    • Remove the small black, white and red cable next to the yellow cable at the top.
  14. ASUS U57A-BBL4 Motherboard Replacement: step 14, image 1 of 1
    • Carefully and slowly lift up the motherboard from the base and remove the red and black cable underneath the motherboard in the top left corner near the fan.
    • The motherboard and fan are still attached to each other, but are loose from the base.
  15. ASUS U57A-BBL4 Motherboard Replacement: step 15, image 1 of 1
    • Remove the four 2 mm Phillips head screws surrounding the copper rod using PH1 screw driver.
  16. ASUS U57A-BBL4 Motherboard Replacement: step 16, image 1 of 1
    • Remove the red, blue, black and yellow cable attaching the fan and motherboard together with your fingers.
    • Now the motherboard and fan are completely separate from each other.
Isabella Bernardi
671 Reputation
6 Guides authored
2 Comments
Awesome! I have this exact computer mentioned (u57a bbL4) and am having the same problems you've mentioned, so I'm considering buying and replacing the motherboard. I noticed that there is a U57A k554 motherboard, not sure but is this an upgrade? Is there a motherboard that is an upgrade all the while fitting all of the other specifications for the elements? cpu, ram, hd etc? I am going to get a motherboard and a ssd .
Thanks for the info!
Dave C - Reply
I am not sure about the U57A K554 being the upgrade to the previous one but since it has the same series it should not be a problem.
Welcome
Brijesh Patel - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,123
