Introduction
Motherboard is one of the most important parts on a device, This guide will help you take apart your Asus MeMo Pad 7 to get access to your motherboard. This will allow you to replace your motherboard and the device will work properly.
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter. The panel will be glued on and requires pressure to open.
  • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
  • The panel will be glued on and requires pressure to open.
After removing the rear panel, use a plastic openning tool to remove the frame of the tablet. Start in the middle of the top side and insert a plastic opening tool between the screen and the frame. Carefully run the plastic opening tool along all the edges of the tablet.
  • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
  • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
  • Carefully run the plastic opening tool along all the edges of the tablet.
When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Disconnect the ZIF connectors to release the data cables holding the battery in.  Use tweezers to do this. You can also use your hand to remove ZIF connectors. ZIF connectors are delicate so be careful when you are removing them.
  • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
  • You can also use your hand to remove ZIF connectors.
  • ZIF connectors are delicate so be careful when you are removing them.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery. The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out. The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
  • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
  • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
After removing the battery from the device, locate the volume connectors on the side of the device. Using tweezers, carefully remove the volume connectors and place it to the side.
  • After removing the battery from the device, locate the volume connectors on the side of the device.
  • Using tweezers, carefully remove the volume connectors and place it to the side.
Locate the GPS antenna. Pry off the GPS antenna cable with a spudger. Locate the GPS antenna. Pry off the GPS antenna cable with a spudger.
  • Locate the GPS antenna. Pry off the GPS antenna cable with a spudger.
Locate seven 2mm Phillips #0 screws attaching the motherboard to the pad. Remove the screws with a Phillips #000 screwdriver. Place your screws somewhere you will remember they are at.
  • Locate seven 2mm Phillips #0 screws attaching the motherboard to the pad. Remove the screws with a Phillips #000 screwdriver.
  • Place your screws somewhere you will remember they are at.
There were eight screws on both of the motherboards i just swapped. The last one would be in the top left of the diagram.
mesanos - Reply
Once all the screws are taken out, you can remove the motherboard. Carefully, take the motherboard out with a plastic opening tool.
  • Once all the screws are taken out, you can remove the motherboard. Carefully, take the motherboard out with a plastic opening tool.
3 other people completed this guide.
Tyler Tripp
383 Reputation
3 Guides authored
USF Tampa, Team 14-23, Meier Fall 2015 Member of USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Members
8 Guides authored
One Comment
hi, i need the power supply board where the usb in. please let me know where i can buy one. Asus MeMO Pad 7 (ME572C)
i think it called pcb
Feroz YF - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 72
All Time: 2,379
