Introduction
Sometimes screens stop working. This guide will show you how to replace your screen and get back to browsing.
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
Slide the motherboard to the right and lift it up, but do not pull it completely out.
Flip the laptop back over. The charging port will be located in the top-right corner.
Step 30 ā there are THREE cables (2 ribbon and 1 modular) attached to the face of the motherboard that you cannot see until itās been removed.
Yes indeed, thanks Scot.
Also this guide forgets to remove all the screws around the outside edge, to remove the top cover Step 37. 7 screws by my count. 4 on I/O side, 3 on DVD side
Also Step 33 removing hinges, requires the pictured screw on top of each, as well as 2 underneath each hinge
3 Comments
Thank you for your time!
Now, I donĀ“t know how to connect the cables to the motherboard because they are too short.
