ASUS F550 HDD Replacement
  1. ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 1 of 2 ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 2 of 2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 HDD Replacement, HDD: step 2, image 1 of 1
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. ASUS F550 HDD Replacement, HDD Removal from Caddy: step 3, image 1 of 1
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
5 other people completed this guide.
Ryan
1,414 Reputation
14 Guides authored
One Comment
What is the spec of the hard drive? SATA 2.5"? Any max capacity or other restrictions on what drops in?
mrgilbe1 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 6,209
