You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
If you find the need to replace your motherboard, fan or RAM, then follow this guide. Be sure to remove the Keyboard Module, DVD Drive, and Hard Drive before removing the motherboard.
  1. Use the Philips #1 Screwdriver to remove the 9 screws that hold the keyboard cover in place. Use the Philips #1 Screwdriver to remove the 9 screws that hold the keyboard cover in place.
    • Use the Philips #1 Screwdriver to remove the 9 screws that hold the keyboard cover in place.
  2. Insert the flat edge of the spudger into the crease of the keyboard cover.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. Make sure that the entire cover has been released from the plastic pins. Slowly lift the cover open from the front of the laptop, but do not completely remove.
    • Make sure that the entire cover has been released from the plastic pins.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove.
    • Note the locations of the 3 white and blue data cables connecting to the keyboard to the computer's main board.
  4. Remove each data cable from the motherboard by using your finger or the black spudger to lift the black latch.
    • Remove each data cable from the motherboard by using your finger or the black spudger to lift the black latch.
    • The cable will slide out of its place.
  5. With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
  6. Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver. There are two screws connected to the motherboard and two screws connected directly to the case.
    • Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
    • There are two screws connected to the motherboard and two screws connected directly to the case.
  7. Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
    • Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
    • Be sure to fully disconnect the hard drive from the motherboard to ensure that you do not damage the connectors.
    • If necessary, unscrew the old hard drive from the holster and screw the new one into the holster.
  8. Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver. Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
  9. Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
  10. The manufacturer warns to only allow a professional to remove the battery.   Do so at your own risk. Do not use any metal tool to pry any type of battery.  Doing so can puncture or short the battery, resulting in damage or injury.
    • The manufacturer warns to only allow a professional to remove the battery. Do so at your own risk.
    • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
    • Remove the two screws securing the battery to the laptop case with the Phillips #1 screwdriver.
  11. After removing the 2 screws, pull out the battery. The battery is connected to the motherboard on the left side.
    • After removing the 2 screws, pull out the battery.
    • The battery is connected to the motherboard on the left side.
    • Use your finger tips to evenly grip the battery on the left and right sides of the battery.
    • Pull straight up to lift the battery out of its place.
    • If you find yourself having trouble pulling out the battery, push the battery back in place and attempt to lift straight out again.
    • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
  12. Locate the Network Interface Card (NIC) on the motherboard. Note the orientation of the white and black wires on your NIC.  The may connection differ from the picture. Gently disconnect the white and black wires by pulling it off of the NIC card.  These wires should come off easy.
    • Locate the Network Interface Card (NIC) on the motherboard.
    • Note the orientation of the white and black wires on your NIC. The may connection differ from the picture.
    • Gently disconnect the white and black wires by pulling it off of the NIC card. These wires should come off easy.
    • If you are following these steps for the prerequisite to remove the motherboard, you do not need to completely remove the NIC. Just remove the wires. The proceeding step can be skipped.
  13. Remove the screws that are holding down the wireless network card with the Phillips #1 screwdriver. After removing the screws, the NIC will lift up in a spring action.
    • Remove the screws that are holding down the wireless network card with the Phillips #1 screwdriver.
    • After removing the screws, the NIC will lift up in a spring action.
  14. Gently pull out the NIC.
    • Gently pull out the NIC.
    • Do not use excessive force or wiggle the card out. The NIC should slide out easily.
  15. Remove the 9 screws from the motherboard using the Philips #1 screwdriver. While unscrewing the screws, it may be helpful to use the tweezers to keep control of the screws.
    • Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
    • While unscrewing the screws, it may be helpful to use the tweezers to keep control of the screws.
  16. Disconnect the three cables attached to the motherboard. Do not pull the cables by their wires.  This can lead to damage to the cables. The large, black cable is connected to the screen.  Carefully wiggle the cable out by gripping the black tape with your fingers.
    • Disconnect the three cables attached to the motherboard.
    • Do not pull the cables by their wires. This can lead to damage to the cables.
    • The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
    • There may be clear tape holding the screen connector in place.
    • The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
  17. Ensure that no devices are plugged in to any peripheral connectors on the left, such as USB or HDMI connections.
    • Ensure that no devices are plugged in to any peripheral connectors on the left, such as USB or HDMI connections.
    • Pull the motherboard to the right to clear the peripheral connections of the laptop casing.
    • Lift the motherboard out of the laptop.
Richard Johnson
662 Reputation
5 Guides authored
IUPUI, Team 1-2, Baechle Fall 2015 Member of IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 769
