Introduction
If your battery is worn or defective, this guide will show you how to replace your battery. The battery is located internally in the laptop and requires removal of the keyboard module for access.
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
I need assistance. When I opened the cover, exposing the keyboard and main board I pulled the 3 blue and white data cables from the main board. How can I repair this? Someone please help!!!!!!
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 other people completed this guide.
2 Comments
No need to disconnect the ribbon cables to gain access to the battery. Gently move keyboard toward you to expose the battery.
Very nice and well explained! Bravo! Easy steps! Congratulations! :-)
