Introduction
This guide will show you how to replace a broken or dysfunctional keyboard on your Chromebook. Before starting, remember to completely disconnect your device from any power sources and ensure your device is turned off. Always use caution when working with electronic components.
Parts
No parts required.
Flip the Chromebook over so the bottom of the device is facing up.
  • Flip the Chromebook over so the bottom of the device is facing up.
Using the JIS-J0 Screwdriver, remove the following screws from the bottom: (5) Five 6mm screws
  • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
  • (5) Five 6mm screws
  • (6) Six 8mm screws
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Gently wedge  the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open.  Then, carefully  lift up on keyboard. Gently wedge  the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open.  Then, carefully  lift up on keyboard. Gently wedge  the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open.  Then, carefully  lift up on keyboard.
  • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
Gently detach connecting cables. Carefully flip up the large black tab. Carefully flip up small white tab.
  • Gently detach connecting cables.
  • Carefully flip up the large black tab.
  • Carefully flip up small white tab.
  • Remove the corresponding black cable.
  • Remove the corresponding white cable.
  • The keyboard will be fully detached at this point.
Gina Altimari
401 Reputation
4 Guides authored
USF Tampa, Team S2-G5, Passmore Fall 2017 Member of USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 82
