Introduction
In the occurrence that you have a corrupted memory storage compartment in your computer or require more computer storage space. Then the M.2 SSD (solid state drive) should be considered to replace and or fill this compartment. In the case your computer storage has been corrupt it may be results of using an old HDD (Hard Disk Drive) as they use mechanical parts that wear down over time. The beneficial advantages SSDs have over HDDs is their reliability and sustainability. They are comprised of less and smaller components while providing more storage space on your computer. This guide will go over the basic procedure to open your computer and install an M.2 SSD onto your motherboard. The instructions are universal towards pre-built and bare bone motherboards (mother board by itself). This will address the problem associated with corrupted storage space, and the requirements to fill this space. It will go over the procedures to install this fast and advantageous memory storage component, adding more storage space to your computer.
To reassemble your device, follow these instructions in reverse order. These steps will vary if you are dissembling your own computer.
3 other people completed this guide.
