AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement
  1. AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement, Sacrificial Anode Rod: step 1, image 1 of 2 AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement, Sacrificial Anode Rod: step 1, image 2 of 2
    • Turn off the power and water supply to the water heater tank.
  2. AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 2, image 1 of 2 AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 2, image 2 of 2
    • Drain the water heater tank using a flathead screwdriver (optional but recommended).
  3. AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 3, image 1 of 2 AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 3, image 2 of 2
    • Locate the sacrificial anode rod, and loosen and remove the old anode rod using the socket wrench.
  4. AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 4, image 1 of 2 AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 4, image 2 of 2
    • Use the socket wrench to loosen the old sacrificial anode rod, and physically extract it from the tank.
    • To install the new sacrificial anode rod, lower it into the tank and tighten using the socket wrench, securing its place.
  5. AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 5, image 1 of 2 AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 5, image 2 of 2
    • Close the drain valve and refill the tank (reverse the steps from draining the tank).
  6. AO Smith 100 50-Gallon Water Heater Sacrificial Anode Rod Replacement: step 6, image 1 of 1
    • Turn on the power or gas supply and check for leaks (reverse the steps from turning off the tank).
Finish Line
Emma Hans
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 136
All Time: 468
