Shop the Holiday Gift Guide
AEG Electrolux FM72 Disassembly for cleaning
Views: 8.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
114
All Time:
8,281
Comments: 3
3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The normal method of cleaning was not effective. In this case the Dustbuster itself needed to be removed and cleaned.
    1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: step 1, image 1 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: step 1, image 2 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: step 1, image 3 of 3
      • Open the lid by pressing the grey button and lifting it away.
      • Clean each of the plastic parts with soap and water, and then leave them out to dry.
      Ask FixBot
    2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: step 2, image 1 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: step 2, image 2 of 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: step 2, image 3 of 3
      • Follow these steps to open the electronic casing.
      • Remove the four screws as shown in picture two.
      • A long Phillips screwdriver is needed for step two.
      • Remove the fifth screw at the bottom as shown in picture three.
      Ask FixBot
    3. AEG Electrolux FM72 Disassembly for cleaning: step 3, image 1 of 3 AEG Electrolux FM72 Disassembly for cleaning: step 3, image 2 of 3 AEG Electrolux FM72 Disassembly for cleaning: step 3, image 3 of 3
      • Gently pry the device open, using an iSesamo opener.
      • Now the I/O button can be removed.
      • Completely replacing this entire part requires desoldering wire connections.
      Ask FixBot
    4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: step 4, image 1 of 2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: step 4, image 2 of 2
      • Now the electronic components can be cleaned using an air compressor.
      • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
      • If the dust bag needs to be replaced, remove its securing screws.
      Ask FixBot
3 other people completed this guide.
Author
with
Kevin D
7,577 Reputation
21 Guides authored
3 Guide Comments
Hello
How can i repair the electric wire on this device please ?
Heloise - Reply Share
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Reply Share
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 114
All Time: 8,281
