AEG Electrolux Competence B33512 fan temperature switch replacement
  1. AEG Electrolux Competence B33512 fan temperature switch replacement, fan temperature switch: step 1, image 1 of 2 AEG Electrolux Competence B33512 fan temperature switch replacement, fan temperature switch: step 1, image 2 of 2
    • All out the mains plug first as it is life-threatening to work on an open device which is still connected to the power.
    • Remove both screws that are used to hold the oven in place
    • Cautiously pull out the oven and place it on a small table. Be prepared for medium weight and use the handles in the middle of the oven on both sides.
  2. AEG Electrolux Competence B33512 fan temperature switch replacement: step 2, image 1 of 1
    • Remove the two screws,
    • now slide the top metal sheet to the rear end of the oven
    • until you are able to lift the front edge of it and remove it entirely.
  3. AEG Electrolux Competence B33512 fan temperature switch replacement: step 3, image 1 of 3 AEG Electrolux Competence B33512 fan temperature switch replacement: step 3, image 2 of 3 AEG Electrolux Competence B33512 fan temperature switch replacement: step 3, image 3 of 3
    • Cautiously pull out the ends of both white cables
    • Also pull out the light blue ones
    • This is the switch, hidden in cables
  4. AEG Electrolux Competence B33512 fan temperature switch replacement: step 4, image 1 of 1
    • Now put in the new switch and pay attention that it doesn't touch any metal surfaces that may get hot
  5. AEG Electrolux Competence B33512 fan temperature switch replacement: step 5, image 1 of 2 AEG Electrolux Competence B33512 fan temperature switch replacement: step 5, image 2 of 2
    • If the heating and the light don't work after reassembling the oven, press a button or re-set the clock to its actual time. The heating should immediately start then.
To reassemble your device, follow these instructions in reverse order
2 other people completed this guide.
Special thanks to these translators:
de en
100%
Bjarne is helping us fix the world! Want to contribute?
Start translating ›
Bjarne
356 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 14
Past 7 Days: 41
Past 30 Days: 150
All Time: 5,920
