Tools
Parts
Loosen the water and sewage hose
Remove screws securing the top cover
Lift the lid at the back and slide it out to the rear
Remove water hose
Disconnect the power plug
Remove plastic caps at the bottom right + left
Remove screws according to pictures (and only these !!!)
Remove rear housing part
The shock absorbers are situated to the right and to the left. The right one is extremely difficult to access.
To remove the pins, the lock must be pressed down at the front end.
The installation position is marked on the shock absorber.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
91%
These translators are helping us fix the world! Want to contribute?
Start translating ›
