AEG Öko Lavamat 1571 Shock Absorber Replacement
  1. AEG Öko Lavamat 1571 Shock Absorber Replacement, Remove upper lid: step 1, image 1 of 2 AEG Öko Lavamat 1571 Shock Absorber Replacement, Remove upper lid: step 1, image 2 of 2
    • Unplug the power plug !!!
    • Loosen the water and sewage hose
    • Remove screws securing the top cover
    • Lift the lid at the back and slide it out to the rear
  2. AEG Öko Lavamat 1571 Shock Absorber Replacement, Prepare removal of the rear housing part: step 2, image 1 of 3 AEG Öko Lavamat 1571 Shock Absorber Replacement, Prepare removal of the rear housing part: step 2, image 2 of 3 AEG Öko Lavamat 1571 Shock Absorber Replacement, Prepare removal of the rear housing part: step 2, image 3 of 3
    • Remove water hose
    • Disconnect the power plug
    • Remove plastic caps at the bottom right + left
  3. AEG Öko Lavamat 1571 Shock Absorber Replacement, Remove rear housing: step 3, image 1 of 3 AEG Öko Lavamat 1571 Shock Absorber Replacement, Remove rear housing: step 3, image 2 of 3 AEG Öko Lavamat 1571 Shock Absorber Replacement, Remove rear housing: step 3, image 3 of 3
    • Remove screws according to pictures (and only these !!!)
    • Remove rear housing part
    • Caution: The rear housing part is part of the load-bearing structure! The case is now slightly twisted.
  4. AEG Öko Lavamat 1571 Shock Absorber Replacement, Shock absorber replacement: step 4, image 1 of 2 AEG Öko Lavamat 1571 Shock Absorber Replacement, Shock absorber replacement: step 4, image 2 of 2
    • The shock absorbers are situated to the right and to the left. The right one is extremely difficult to access.
    • To remove the pins, the lock must be pressed down at the front end.
    • The installation position is marked on the shock absorber.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Michael S.
636 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 69
All Time: 6,364
