5G mmWave Antenna Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. 5G mmWave Antenna Removal, Safety precautions: step 1, image 1 of 2 5G mmWave Antenna Removal, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. 5G mmWave Antenna Removal, Adhesive information: step 2, image 1 of 3 5G mmWave Antenna Removal, Adhesive information: step 2, image 2 of 3 5G mmWave Antenna Removal, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. 5G mmWave Antenna Removal, Apply a suction handle: step 3, image 1 of 2 5G mmWave Antenna Removal, Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. 5G mmWave Antenna Removal, Insert an opening pick: step 4, image 1 of 3 5G mmWave Antenna Removal, Insert an opening pick: step 4, image 2 of 3 5G mmWave Antenna Removal, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. 5G mmWave Antenna Removal, Separate the rear cover adhesive: step 5, image 1 of 3 5G mmWave Antenna Removal, Separate the rear cover adhesive: step 5, image 2 of 3 5G mmWave Antenna Removal, Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. 5G mmWave Antenna Removal: step 6, image 1 of 3 5G mmWave Antenna Removal: step 6, image 2 of 3 5G mmWave Antenna Removal: step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. 5G mmWave Antenna Removal: step 7, image 1 of 3 5G mmWave Antenna Removal: step 7, image 2 of 3 5G mmWave Antenna Removal: step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. 5G mmWave Antenna Removal, Prop up the rear cover: step 8, image 1 of 3 5G mmWave Antenna Removal, Prop up the rear cover: step 8, image 2 of 3 5G mmWave Antenna Removal, Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. 5G mmWave Antenna Removal, Remove the cable cover: step 9, image 1 of 2 5G mmWave Antenna Removal, Remove the cable cover: step 9, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. 5G mmWave Antenna Removal: step 10, image 1 of 2 5G mmWave Antenna Removal: step 10, image 2 of 2
    • Use tweezers or your fingers to remove the cable cover.
  11. 5G mmWave Antenna Removal, Disconnect the rear cover: step 11, image 1 of 3 5G mmWave Antenna Removal, Disconnect the rear cover: step 11, image 2 of 3 5G mmWave Antenna Removal, Disconnect the rear cover: step 11, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. 5G mmWave Antenna Removal, Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. 5G mmWave Antenna Removal, Peel up the cable cover tape: step 13, image 1 of 3 5G mmWave Antenna Removal, Peel up the cable cover tape: step 13, image 2 of 3 5G mmWave Antenna Removal, Peel up the cable cover tape: step 13, image 3 of 3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. 5G mmWave Antenna Removal, Remove the cable cover: step 14, image 1 of 2 5G mmWave Antenna Removal, Remove the cable cover: step 14, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. 5G mmWave Antenna Removal: step 15, image 1 of 2 5G mmWave Antenna Removal: step 15, image 2 of 2
    • Use tweezers or your fingers to remove the cover.
  16. 5G mmWave Antenna Removal, Disconnect the wireless charging assembly: step 16, image 1 of 2 5G mmWave Antenna Removal, Disconnect the wireless charging assembly: step 16, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. 5G mmWave Antenna Removal: step 17, image 1 of 3 5G mmWave Antenna Removal: step 17, image 2 of 3 5G mmWave Antenna Removal: step 17, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. 5G mmWave Antenna Removal, Remove the wireless charging assembly screws: step 18, image 1 of 2 5G mmWave Antenna Removal, Remove the wireless charging assembly screws: step 18, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. 5G mmWave Antenna Removal, Remove the wireless charging assembly: step 19, image 1 of 2 5G mmWave Antenna Removal, Remove the wireless charging assembly: step 19, image 2 of 2
    • Remove the wireless charging assembly.
  20. 5G mmWave Antenna Removal, Disconnect the battery: step 20, image 1 of 3 5G mmWave Antenna Removal, Disconnect the battery: step 20, image 2 of 3 5G mmWave Antenna Removal, Disconnect the battery: step 20, image 3 of 3
    • Use a spudger to pry up and disconnect the battery press connector.
  21. 5G mmWave Antenna Removal, Remove the 5G mmWave cover screw: step 21, image 1 of 2 5G mmWave Antenna Removal, Remove the 5G mmWave cover screw: step 21, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.2 mm‑long screw securing the mmWave antenna cover.
  22. 5G mmWave Antenna Removal, Remove the 5G mmWave cover: step 22, image 1 of 3 5G mmWave Antenna Removal, Remove the 5G mmWave cover: step 22, image 2 of 3 5G mmWave Antenna Removal, Remove the 5G mmWave cover: step 22, image 3 of 3
    • A tight metal clip secures the bottom left corner of the mmWave antenna cover.
    • Insert the point of a spudger under the tab near the bottom left corner of the mmWave antenna cover.
    • Use your spudger to slide the cover to the right while prying up to unclip the cover.
  23. 5G mmWave Antenna Removal: step 23, image 1 of 3 5G mmWave Antenna Removal: step 23, image 2 of 3 5G mmWave Antenna Removal: step 23, image 3 of 3
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  24. 5G mmWave Antenna Removal, Disconnect the 5G mmWave antenna: step 24, image 1 of 2 5G mmWave Antenna Removal, Disconnect the 5G mmWave antenna: step 24, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  25. 5G mmWave Antenna Removal, Disconnect the front facing camera: step 25, image 1 of 2 5G mmWave Antenna Removal, Disconnect the front facing camera: step 25, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  26. 5G mmWave Antenna Removal, Remove the 5G mmWave screw: step 26, image 1 of 3 5G mmWave Antenna Removal, Remove the 5G mmWave screw: step 26, image 2 of 3 5G mmWave Antenna Removal, Remove the 5G mmWave screw: step 26, image 3 of 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.2 mm‑long screw securing the mmWave antenna.
  27. 5G mmWave Antenna Removal, Remove the 5G mmWave antenna: step 27, image 1 of 2 5G mmWave Antenna Removal, Remove the 5G mmWave antenna: step 27, image 2 of 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
Finish Line
Spencer Day
118,962 Reputation
838 Guides authored
iFixit Member of iFixit
Staff
119 Members
21,701 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 44
