Shop the Holiday Gift Guide
2022 Nissan Rogue Key Fob Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
105
All Time:
708
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Is the key fob for your 2022 Nissan Rogue not working properly? Chances are that you might need to replace the battery, as it is very common for them to stop working. This is a very easy fix, with minimal tools required. This fix does not pose any risks, and should be a seamless fix. For this fix, you will need estimated 10 minutes to complete. Continue reading below to see a step by step guide of how to replace the battery.
Parts
Tools
  • Spudger
    4.9
Video Overview
    1. 2022 Nissan Rogue Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 2 2022 Nissan Rogue Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 2
      • Use your hands to remove the key from the back of the key fob.
      Ask FixBot
    2. 2022 Nissan Rogue Key Fob Battery Replacement: step 2, image 1 of 1
      • Use a spudger to remove the back plate from the key fob.
      Ask FixBot
    3. 2022 Nissan Rogue Key Fob Battery Replacement: step 3, image 1 of 1
      • Remove the small silver coin battery using your nails or a spudger.
      • Once you have removed the coin battery, you may insert your new battery in the exact place the hold one was held.
      Ask FixBot
    4. 2022 Nissan Rogue Key Fob Battery Replacement: step 4, image 1 of 1
      • The back plate can now be snapped back into place, and then you can proceed to put the detached key back into the fob. You have now replaced the battery for your 2022 Nissan Rogue key fob.
      Ask FixBot
Finish Line
Author
with
Allison
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 105
All Time: 708
