2021 Nissan Kicks Air Filter Replacement
  1. 2021 Nissan Kicks Air Filter Replacement, Prepare Your Vechile: step 1, image 1 of 1
    • Ensure your Nissan Kicks is parked on a level surface and the engine is cool. Open the hood and locate the air filter housing on the engine compartment. It is usually a black, plastic box.
    Ask FixBot
  2. 2021 Nissan Kicks Air Filter Replacement, Open the Air Filter Housing: step 2, image 1 of 1
    • Release the two retaining clips around the edges of the air filter housing.
    Ask FixBot
  3. 2021 Nissan Kicks Air Filter Replacement, Remove the Old Air Filter: step 3, image 1 of 3 2021 Nissan Kicks Air Filter Replacement, Remove the Old Air Filter: step 3, image 2 of 3 2021 Nissan Kicks Air Filter Replacement, Remove the Old Air Filter: step 3, image 3 of 3
    • Pull forward slightly to release the holders at the back of the housing unit. Pull the housing unit upward and remove the old air filter. Note the orientation as you remove it to ensure the new filter is installed correctly.
    Ask FixBot
  4. 2021 Nissan Kicks Air Filter Replacement, Clean the Air Filter Housing: step 4, image 1 of 1
    • Before installing the new air filter, use a clean, dry cloth to wipe out any dirt or debris inside the air filter housing. Ensure the housing is clean to avoid contaminating the new filter.
    Ask FixBot
  5. 2021 Nissan Kicks Air Filter Replacement, Install the New Air Filter: step 5, image 1 of 1
    • Place the new air filter into the housing, ensuring it fits snugly and is correctly oriented. Air filters are designed to fit one way, so ensure the edges align correctly with the housing.
    Ask FixBot
  6. 2021 Nissan Kicks Air Filter Replacement, Reassemble the Air Filter Housing: step 6, image 1 of 3 2021 Nissan Kicks Air Filter Replacement, Reassemble the Air Filter Housing: step 6, image 2 of 3 2021 Nissan Kicks Air Filter Replacement, Reassemble the Air Filter Housing: step 6, image 3 of 3
    • Once the new air filter is in place, reattach the top of the housing. Ensure the housing tabs fit accurately into the slots at the back of the housing, and then secure the spring clips. Ensure all clips are tightly fastened to prevent unfiltered air from entering the engine.
    Ask FixBot
  7. 2021 Nissan Kicks Air Filter Replacement, Final Check: step 7, image 1 of 1
    • Double-check to make sure everything is secure. Close the hood and start your vehicle to ensure everything is working correctly. Listen for any unusual sounds indicating that the housing is not sealed properly.
    Ask FixBot
Replacing the air filter on your 2021 Nissan Kicks is a simple process critical to maintaining your vehicle's performance and longevity. Following these steps ensures your engine receives clean air, improving fuel efficiency and prolonging its life. This task requires no special tools and can be completed in about 15 minutes, making it an easy and effective way to maintain your vehicle yourself.
Ashley Shamp
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 99
All Time: 1,008
