2019 Volvo S60 Key Fob Battery Replacement
  1. 2019 Volvo S60 Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2019 Volvo S60 Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2019 Volvo S60 Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • Place the key with the Volvo logo facing up and the keyring loop facing you.
    • Slide the small latch on the left to the side, and lift the cover off.
  2. 2019 Volvo S60 Key Fob Battery Replacement: step 2, image 1 of 3 2019 Volvo S60 Key Fob Battery Replacement: step 2, image 2 of 3 2019 Volvo S60 Key Fob Battery Replacement: step 2, image 3 of 3
    • Slide the second latch under the front cover, and lift the rear cover off.
    • This will reveal an internal, physical key on one side and a round battery cover on the other side.
  3. 2019 Volvo S60 Key Fob Battery Replacement: step 3, image 1 of 2 2019 Volvo S60 Key Fob Battery Replacement: step 3, image 2 of 2
    • Use a flathead screwdriver to twist the battery cover counterclockwise into the Open position.
    • Lift the battery cover to remove it.
  4. 2019 Volvo S60 Key Fob Battery Replacement: step 4, image 1 of 3 2019 Volvo S60 Key Fob Battery Replacement: step 4, image 2 of 3 2019 Volvo S60 Key Fob Battery Replacement: step 4, image 3 of 3
    • Remove the battery.
    • Insert the replacement with the + side facing out.
    • Make sure to press the new battery down until it catches.
    • It is recommended to only minimally touch the battery directly with your fingers.
  5. 2019 Volvo S60 Key Fob Battery Replacement: step 5, image 1 of 2 2019 Volvo S60 Key Fob Battery Replacement: step 5, image 2 of 2
    • Reposition the battery cover over the battery and use the screwdriver to turn clockwise to the Close position.
  6. 2019 Volvo S60 Key Fob Battery Replacement: step 6, image 1 of 3 2019 Volvo S60 Key Fob Battery Replacement: step 6, image 2 of 3 2019 Volvo S60 Key Fob Battery Replacement: step 6, image 3 of 3
    • Refit the outer covers in the manner they were removed.
    • The rear cover does not have a logo and can be snapped into place first, followed by the front cover with the Volvo logo.
    • When the covers are securely clicked into place, you should see no gaps along the seams.
    • The key should be functional immediately and can be tested by using it normally to unlock the vehicle.
Zachary
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 76
All Time: 406
