2019 GMC Acadia Headlight Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
38
Past 30 Days:
149
All Time:
510
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your headlamps on your 2019 GMC Acadia are dimmer than usual, flickering on and off or do not turn on, use this guide to replace the headlamp bulb(s).
The headlamps are responsible for providing illumination for high and low-beam functions, ensuring visibility, and safety during nighttime driving.
Before using this guide, make sure that the headlamp malfunction is not due to any of the following:
Be sure that you have thoroughly followed the steps of each malfunction resolution to the listed headlamp issues to confirm that the problem is a faulty bulb.
Before beginning, make sure that you avoid touching the bulb with your naked hands or fingers to prevent getting oils on the bulb that will potentially damage it or shorten its lifespan. The replacement process is identical on both sides.
    1. 2019 GMC Acadia Headlight Replacement, Headlight Bulb: step 1, image 1 of 3 2019 GMC Acadia Headlight Replacement, Headlight Bulb: step 1, image 2 of 3 2019 GMC Acadia Headlight Replacement, Headlight Bulb: step 1, image 3 of 3
      • Access the bulb housing by lifting the hood of the car.
      • The bulb is behind the headlamp in the interior of the engine compartment.
      Ask FixBot
    2. 2019 GMC Acadia Headlight Replacement: step 2, image 1 of 2 2019 GMC Acadia Headlight Replacement: step 2, image 2 of 2
      • Reach into the opening for the domed cap.
      Ask FixBot
    3. 2019 GMC Acadia Headlight Replacement: step 3, image 1 of 3 2019 GMC Acadia Headlight Replacement: step 3, image 2 of 3 2019 GMC Acadia Headlight Replacement: step 3, image 3 of 3
      • Grip the base of the bulb with your thumb and forefinger.
      • Twist the socket counterclockwise.
      • Once turned, pull the bulb straight back out of the socket.
      Ask FixBot
    4. 2019 GMC Acadia Headlight Replacement: step 4, image 1 of 3 2019 GMC Acadia Headlight Replacement: step 4, image 2 of 3 2019 GMC Acadia Headlight Replacement: step 4, image 3 of 3
      • Detach the bulb from the socket cord.
      • Release the locking clip from the socket cord and the bulb.
      • Gently pull the socket cord from the bulb.
      Ask FixBot
    5. 2019 GMC Acadia Headlight Replacement: step 5, image 1 of 3 2019 GMC Acadia Headlight Replacement: step 5, image 2 of 3 2019 GMC Acadia Headlight Replacement: step 5, image 3 of 3
      • Install the new bulb.
      • WARNING: Do not touch the new bulb with your bare fingers. Oil from your hands will damage the bulb and shorten its lifespan.
      • Optional: Wear gloves when handling the lightbulb.
      • Line up the lock to make sure it attaches properly.
      Ask FixBot
    6. 2019 GMC Acadia Headlight Replacement: step 6, image 1 of 2 2019 GMC Acadia Headlight Replacement: step 6, image 2 of 2
      • Snap the bulb into the socket cord.
      Ask FixBot
    7. 2019 GMC Acadia Headlight Replacement: step 7, image 1 of 2 2019 GMC Acadia Headlight Replacement: step 7, image 2 of 2
      • Align the notches on the base of the lightbulb with the notches on the socket housing.
      • Insert the bulb into the socket housing.
      Ask FixBot
    8. 2019 GMC Acadia Headlight Replacement: step 8, image 1 of 2 2019 GMC Acadia Headlight Replacement: step 8, image 2 of 2
      • Turn the bulb clockwise to secure.
      Ask FixBot
    9. 2019 GMC Acadia Headlight Replacement: step 9, image 1 of 1
      • Check the light.
      Ask FixBot
    10. 2019 GMC Acadia Headlight Replacement: step 10, image 1 of 2 2019 GMC Acadia Headlight Replacement: step 10, image 2 of 2
      • Reinstall the back cap to the light fixture.
      Ask FixBot
    11. 2019 GMC Acadia Headlight Replacement: step 11, image 1 of 1
      • Your headlight is fixed!
      Ask FixBot
Your headlight is now replaced.
Lorie Anderson
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 149
All Time: 510
