Introduction
If the seat adjustment switch in your 2015 Infiniti Q50 is no longer functioning properly or has lost its ability to adjust the seat up or down, it is likely due to a dead battery, which will require a replacement.
A functional battery provides consistent power to the seat adjustment switches, ensuring that people can easily adjust seating positions for comfort and driving posture. If you notice that the seat switch doesn't allow you to adjust the seating position from seating up or down, you might just have a faulty seat switch. If the seat doesn't move even after buying a new set of seat switches, then you do have a faulty battery. You should change this as it allows the seat to be positioned precisely which allows comfort and safety.
Make sure to disconnect the car battery before you begin.
Remove a total of four covers on the seat (two in the front and two in the back).
