2015 Ford C-Max Windshield Wiper Replacement
  1. 2015 Ford C-Max Windshield Wiper Replacement, Windshield Wiper: step 1, image 1 of 2 2015 Ford C-Max Windshield Wiper Replacement, Windshield Wiper: step 1, image 2 of 2
    • The default wiper position keeps the blades tucked beneath the hood, making them difficult to access. These images show the wipers in their stowed position, viewed from both inside and outside the vehicle.
    Ask FixBot
  2. 2015 Ford C-Max Windshield Wiper Replacement: step 2, image 1 of 1
    • Press the ignition button without pressing the brake pedal to turn on the vehicle’s auxiliary power.
    • This powers the electronics without starting the engine.
    Ask FixBot
  3. 2015 Ford C-Max Windshield Wiper Replacement: step 3, image 1 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 3, image 2 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 3, image 3 of 3
    • Within three seconds of turning on auxiliary power, push the wiper control stalk on the right side of the steering wheel downward once to activate the wipers.
    • This moves them into service mode, positioning the blades vertically for easier access.
    • Once they stop moving, press the ignition button again to turn the car off.
    • The second and third images show the wipers in the service position.
    Ask FixBot
  4. 2015 Ford C-Max Windshield Wiper Replacement: step 4, image 1 of 2 2015 Ford C-Max Windshield Wiper Replacement: step 4, image 2 of 2
    • Squeeze the release clips on the wiper adapter while swiveling the clasp outward to unlock it.
    • Perform this action on both front wipers.
    • The first image shows where to press, and the second shows the adapter flipped open.
    • These adapter instructions are specific to the Rain-X Rugged XL wipers. Follow your specific wiper manufacturer's instructions.
    Ask FixBot
  5. 2015 Ford C-Max Windshield Wiper Replacement: step 5, image 1 of 2 2015 Ford C-Max Windshield Wiper Replacement: step 5, image 2 of 2
    • Squeeze the sides of the adapter to release it.
    • Then lift it straight up to remove.
    • The first image shows where to squeeze, and the second shows the adapter being lifted off.
    Ask FixBot
  6. 2015 Ford C-Max Windshield Wiper Replacement: step 6, image 1 of 1
    • Pull the blue insert straight out from the adapter to remove it.
    Ask FixBot
  7. 2015 Ford C-Max Windshield Wiper Replacement: step 7, image 1 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 7, image 2 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 7, image 3 of 3
    • Squeeze the pressure release tabs and rotate the wiper blade outward to unlock it.
    • Once released, lift the blade off the mounting tab to remove it completely.
    Ask FixBot
  8. 2015 Ford C-Max Windshield Wiper Replacement: step 8, image 1 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 8, image 2 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 8, image 3 of 3
    • Align the bottom edge of the new wiper as shown in the first image.
    • Seat the wiper fully onto the mounting tab, as seen in the second image.
    • Close the top clasp to secure the new wiper in place.
    Ask FixBot
  9. 2015 Ford C-Max Windshield Wiper Replacement: step 9, image 1 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 9, image 2 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 9, image 3 of 3
    • Squeeze the pressure tabs on the passenger-side wiper and rotate the blade toward the windshield to release it.
    • Once released, lift the old wiper off to remove it completely.
    • This step is identical to the driver's side front wiper.
    Ask FixBot
  10. 2015 Ford C-Max Windshield Wiper Replacement: step 10, image 1 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 10, image 2 of 3 2015 Ford C-Max Windshield Wiper Replacement: step 10, image 3 of 3
    • Align the bottom edge of the new passenger-side wiper as shown in the first image.
    Ask FixBot
  11. 2015 Ford C-Max Windshield Wiper Replacement: step 11, image 1 of 1
    • Remove the yellow protective covers from your new wiper blades.
    • Place the wipers gently on the windshield. Do not let the wipers slam back against the windshield.
    • Perform this step on both the driver's side and passenger side wipers.
    Ask FixBot
  12. 2015 Ford C-Max Windshield Wiper Replacement: step 12, image 1 of 2 2015 Ford C-Max Windshield Wiper Replacement: step 12, image 2 of 2
    • Start the car by pressing the brake pedal and the ignition.
    • Push the wiper control stalk downward (on the right side of the steering wheel) to activate the wipers. This will move the blades into their stowed position.
    • Turn the car off by pressing the ignition button again once the blades are stowed.
    Ask FixBot
You now have new wiper blades! You're free to enjoy a clear driving experience in all kinds of weather.
Sean Lawrence
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 52
All Time: 301
