2015-2021 Volkswagen GTI Cabin Air Filter Replacement
    1. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 3 of 3
      • Open Glove Compartment.
      • Locate the two tabs on the corners of the glove compartment.
      • Push up on both tabs. One at a time or simultaneously.
      • Drop down the glove compartment.
      Ask FixBot
    2. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 2, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 2, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 2, image 3 of 3
      • After dropping down the glove compartment, locate the honeycomb compartment.
      • Behind the compartment is the old cabin air filter.
      • Located on the compartment are three clips. The clips are on the top section of the compartment.
      • To unlatch the three clips, apply pressure onto a flap on the right side while carefully unhooking each clip.
      Ask FixBot
    3. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 3, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 3, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 3, image 3 of 3
      • After removing the honeycomb compartment, set it aside.
      • Remove the old cabin air filter and throw it out.
      • If the filter does not slide out immediately, try pinching on the filter and pulling it out.
      Ask FixBot
    4. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 4, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 4, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 4, image 3 of 3
      • When installing the new air filter, notice the direction of the arrows on your old one.
      • Make sure to have the air flow arrows facing the same way (down). Push into the empty compartment.
      Ask FixBot
    5. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 5, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 5, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 5, image 3 of 3
      • Now we put the honeycomb compartment back.
      • Make sure to insert the lower tab into the slot.
      • It will stay ajar, to seal the compartment, simply apply pressure on the compartment.
      • It will click into place, but to be sure press along the edges.
      Ask FixBot
    6. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 6, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 6, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 6, image 3 of 3
      • Putting the glove compartment back.
      • Follow these steps to follow in order.
      • First, push up on the glove compartment until it clicks.
      • Second, make sure the brake element is assembled; the stick goes into the circular module.
      • Finally, push the glove compartment until you hear the second click.
      Ask FixBot
    7. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 7, image 1 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 7, image 2 of 3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: step 7, image 3 of 3
      • After hearing the second click, the glove compartment should remain open.
      • Finally, you can close the glove compartment.
      Ask FixBot
5 other people completed this guide.
Hector C.
265 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 147
Past 30 Days: 744
All Time: 12,626
