Shop the Holiday Gift Guide
2014 Nissan Juke Key Fob Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
73
Past 30 Days:
261
All Time:
1,457
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 8 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you ever run into issues with your 2014 Nissan Juke not starting or locking or unlocking from the key fob, then a potential issue could be the key fob battery could be dead. This is a helpful step-by-step guide on how to properly replace your Nissan Juke's key fob battery.
Parts
Tools
  • Spudger
    4.9
    1. 2014 Nissan Juke Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 1
      • Flip your key to the back of the key fob.
      • Remove the emergency key from the key fob.
      Ask FixBot
    2. 2014 Nissan Juke Key Fob Battery Replacement: step 2, image 1 of 2 2014 Nissan Juke Key Fob Battery Replacement: step 2, image 2 of 2
      • Gently insert a spudger into a corner of the key fob casing.
      • Push up the spudger to remove both halves of the key fob from each other.
      • Be careful when trying to find a good corner to separate the halves so that the spudger does not stab you.
      Ask FixBot
    3. 2014 Nissan Juke Key Fob Battery Replacement: step 3, image 1 of 1
      • Open up your key fob and look at all the components in your key fob.
      • Pay attention to what side the old battery is facing; it will be helpful for the next step.
      Ask FixBot
    4. 2014 Nissan Juke Key Fob Battery Replacement: step 4, image 1 of 1
      • Remove the old CR2032 battery.
      • Pay attention to what side the old battery was facing.
      Ask FixBot
    5. 2014 Nissan Juke Key Fob Battery Replacement: step 5, image 1 of 2 2014 Nissan Juke Key Fob Battery Replacement: step 5, image 2 of 2
      • Place the new battery in the same position and side the old CR2032 battery was in.
      Ask FixBot
    6. 2014 Nissan Juke Key Fob Battery Replacement: step 6, image 1 of 1
      • Make sure the positive and negative sides are facing the correct direction to ensure that the key fob will work properly.
      Ask FixBot
    7. 2014 Nissan Juke Key Fob Battery Replacement: step 7, image 1 of 2 2014 Nissan Juke Key Fob Battery Replacement: step 7, image 2 of 2
      • Take the two halves of your key fob and snap them together.
      • When snapping them back together be careful to not pinch yourself during the process.
      • Make sure you hear the "snap" sound so that you know the halves have been successfully put back together.
      Ask FixBot
Author
with
Devin wallace
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 73
Past 30 Days: 261
All Time: 1,457
