2014 Cadillac ATS LED Door Projection Lamp Replacement
  1. 2014 Cadillac ATS LED Door Projection Lamp Replacement, LED Door Projection Lamp: step 1, image 1 of 2 2014 Cadillac ATS LED Door Projection Lamp Replacement, LED Door Projection Lamp: step 1, image 2 of 2
    • With the door fully open, kneel to view the panel's underside beneath the map pocket. Run your hand along the bottom edge to locate the rectangular lens flush with the trim; this is the unit you will replace.
  2. 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 2, image 1 of 2 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 2, image 2 of 2
    • Pry out the existing LED projection lamp from the car door.
  3. 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 3, image 1 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 3, image 2 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 3, image 3 of 3
    • Carefully disconnect the power cable connector from the LED projection lamp.
  4. 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 4, image 1 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 4, image 2 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 4, image 3 of 3
    • Connect the new LED projection lamp to the power cable connector.
  5. 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 5, image 1 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 5, image 2 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 5, image 3 of 3
    • Be sure to correctly align the LED projection lamp housing unit with the power cable connector.
  6. 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 6, image 1 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 6, image 2 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 6, image 3 of 3
    • Properly replace the LED projection lamp in the space in the door.
  7. 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 7, image 1 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 7, image 2 of 3 2014 Cadillac ATS LED Door Projection Lamp Replacement: step 7, image 3 of 3
    • Test the LED projection lamp by closing and opening the door.
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 149
