This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
2014年中MacBook Pro 15" 固态硬盘替换
  1. 2014年中MacBook Pro 15" 固态硬盘替换, 后盖: step 1, image 1 of 1
    • 将固定 MacBook Pro 后盖的 P5 五角螺丝拆掉:
    • 8颗 3.0mm 螺丝
    • 2颗 2.3mm 螺丝
  2. 2014年中MacBook Pro 15" 固态硬盘替换: step 2, image 1 of 1
    • 从后盖盖和主机壳夹扣处抬起,从 MacBook Pro上取下后盖。
    • 将取下的后盖放到一边。
  3. 2014年中MacBook Pro 15" 固态硬盘替换, 电池连接器: step 3, image 1 of 1
    • 揭开盖住电池接口的警告标签。
  4. 2014年中MacBook Pro 15" 固态硬盘替换: step 4, image 1 of 2 2014年中MacBook Pro 15" 固态硬盘替换: step 4, image 2 of 2
    • 使用撬棒平头的那端,轻轻地将电池接口直接从逻辑板上的插座中撬出。
    • 弯曲电池电缆,确保电池接口不会意外接触逻辑板。
  5. 2014年中MacBook Pro 15" 固态硬盘替换, SSD 固态硬盘: step 5, image 1 of 1
    • 拧下把SSD固态硬盘固定到主板的 3.1 mm T5 Torx 螺丝。
  6. 2014年中MacBook Pro 15" 固态硬盘替换: step 6, image 1 of 2 2014年中MacBook Pro 15" 固态硬盘替换: step 6, image 2 of 2
    • 轻轻提起最右边 SSD 固态硬盘,把它从主板的槽里直接滑出来。
以相反的顺序来重新组装你的设备。
143 other people completed this guide.
Special thanks to these translators:
en zh
75%
Churan He is helping us fix the world! Want to contribute?
Start translating ›
34 Comments
What about adding a 2nd SSD to this machine? Is that possible? Thanks!
Kim - Reply
I am also wondering the same. Is there a second SSD drive bay?
Greg Bennett -
if i bought the 1TB SSD Im not sure how you clone everything to it before it is installed?
badboy - Reply
Is it possible to install 1TB SSD? What brand should I buy? Or characteristics? Please help me.
JjCruz -
You can use a program such as Carbon Copy Cloner to 'clone' your drive from one to another.
jeffsolano -
Past 24 Hours: 16
Past 7 Days: 122
Past 30 Days: 571
All Time: 290,455
