Introduction
Benutze diese Anleitung, um die Batterie des Funkschlüssels eines Honda Civic der Baujahre 2012 - 2016 zu wechseln.
Lege den Schlüssel mit dem Honda Logo nach oben hin.
Benutze einen Kreuzschlitzschraubendreher #0, um die Schraube zu entfernen.
Führe das flache Ende eines Spudgers in die Öffnung seitlich in den Funkschlüssel ein.
Heble den Schlüssel auseinander, um das Gehäuse zu öffnen.
Bevor du die Batterie herausnimmst, solltest du dir merken, welche Seite (+ oder -) oben liegt. Die Ersatzbatterie muss genau so eingebaut werden.
Entferne die vorhandene Batterie.
Setze die passende neue Batterie in gleicher Lage wie bisher ein.
Um dein Gerät wieder zusammenzubauen, folge diesen Schritten in umgekehrter Reihenfolge.
18 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
26 Comments
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Thanks, Harry!
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Thank you very helpful!!!
