This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
Le remplacement de votre huile peut être un processus enrichissant et agréable. Avec les outils et les pièces nécessaires tout le monde peut effectuer un changement d'huile dans sa bretelle d´accès.
Laissez le moteur de la voiture tourner au ralenti pour 10 minutes.
Vérifiez le niveau d'huile avec la jauge. Elle est située à droite du moteur lorsque le capot est ouvert.
Vérifiez sous la voiture s'il n'y a pas de fuites.
Vous avez terminé le changement d'huile et de filtre sur votre Subaru Forester 2015.
Pour réassembler votre véhicule, suivez ces instructions dans l'ordre inverse.
18 other people completed this guide.
Special thanks to these translators:
92%
These translators are helping us fix the world! Want to contribute?
Start translating ›
14 Comments
Have 2017 Subaru Forester. Book says nothing about removing panel to get to the oil plug and this instruction says nothing about removing the panel to get to the oil plug. Looks like I have to pry the panel off to get to the plug but will call Subaru later today to see what they say. Seems ridiculous to have a panel with 5 keepers that have to be removed every time you change the oil just to get to the oil plug and then say nothing in the book about removing the cover. Your instruction also needs updated regarding the oil plug cover on a 2017 Subaru Forester.
If the location of the oil pan and plug has changed, then a new guide should be created for 2017 models. This is labeled 2012-2016 because it applies to those model years. I'm not familiar with the panel under the 2017, so I can't provide any updates.
leaders or quarts of oil? My2016 forester calls for 5.1 quarts of oil
It's Quarts, not Liters. I had updated it in the tools a while ago but missed it in the step. Updated.
I have a lot of problems with all of my 2016 Forester manuals. They put numbers on the illustrations, but no numbers in the manual. My Sirius XM manual is at least 6 times thicker than the owner's manual. Why isn't there instructions on how to refill all the fluids in the maintenance manual. I don't need to take it to the dealer for everything!
