2011-Present Dodge Charger Key Fob Battery Replacement
    1. 2011-Present Dodge Charger Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2011-Present Dodge Charger Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2011-Present Dodge Charger Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
      • Pull the inner key from key fob.
      • Remove the key chain or any accessories for easy access to key fob.
      Ask FixBot
    2. 2011-Present Dodge Charger Key Fob Battery Replacement: step 2, image 1 of 3 2011-Present Dodge Charger Key Fob Battery Replacement: step 2, image 2 of 3 2011-Present Dodge Charger Key Fob Battery Replacement: step 2, image 3 of 3
      • Use a spudger to gently pry and separate the two halves of the key fob.
      • Be careful and pry slowly to avoid breaking the key fob.
      Ask FixBot
    3. 2011-Present Dodge Charger Key Fob Battery Replacement: step 3, image 1 of 3 2011-Present Dodge Charger Key Fob Battery Replacement: step 3, image 2 of 3 2011-Present Dodge Charger Key Fob Battery Replacement: step 3, image 3 of 3
      • Use a nylon spudger to pry under the battery and remove it from the key fob.
      Ask FixBot
    4. 2011-Present Dodge Charger Key Fob Battery Replacement: step 4, image 1 of 1
      • Insert the new key fob battery into the holder.
      • You will hear a click sound when you push it into the holder.
      Ask FixBot
    5. 2011-Present Dodge Charger Key Fob Battery Replacement: step 5, image 1 of 2 2011-Present Dodge Charger Key Fob Battery Replacement: step 5, image 2 of 2
      • Reassemble the key fob covers.
      • They should snap together.
      • Press down around the edges to ensure the key fob is securely assembled.
      • Slide the car key into key fob.
      Ask FixBot
Edgard Zaragoza
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 90
All Time: 2,145
