2010-2015 Hyundai Elantra Head Lights Replacement
  1. 2010-2015 Hyundai Elantra Head Lights Replacement, Head Lights: step 1, image 1 of 2 2010-2015 Hyundai Elantra Head Lights Replacement, Head Lights: step 1, image 2 of 2
    • Before you begin, disconnect the car battery.
    • Locate the hood release lever inside the cabin near the driver’s side footwell. Pull the lever to release the hood.
    Ask FixBot
  2. 2010-2015 Hyundai Elantra Head Lights Replacement: step 2, image 1 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 2, image 2 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 2, image 3 of 3
    • Slide the hood latch above the Hyundai emblem at the front of the vehicle to unlock the hood.
    • Lift the hood and secure it with the hood prop.
    Ask FixBot
  3. 2010-2015 Hyundai Elantra Head Lights Replacement: step 3, image 1 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 3, image 2 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 3, image 3 of 3
    • Use a 12 mm wrench to remove the single 12 mm bolt.
    • Use a Phillips #2 to remove two 15.0 mm screws securing the headlight assembly.
    Ask FixBot
  4. 2010-2015 Hyundai Elantra Head Lights Replacement: step 4, image 1 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 4, image 2 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 4, image 3 of 3
    • Disconnect the power cable from the back of the headlight.
    • Apply gentle pressure to pull the headlight assembly out from the chassis.
    Ask FixBot
  5. 2010-2015 Hyundai Elantra Head Lights Replacement: step 5, image 1 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 5, image 2 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 5, image 3 of 3
    • Position the headlight assembly securely.
    • Remove the cover protecting the light bulb.
    • Twist the bulb counterclockwise to release it from the socket.
    Ask FixBot
  6. 2010-2015 Hyundai Elantra Head Lights Replacement: step 6, image 1 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 6, image 2 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 6, image 3 of 3
    • Disconnect the old bulb from the power connector, avoiding contact with the bulb glass.
    • Insert the new bulb into the connector, ensuring a secure fit before placing it back into the headlight assembly.
    Ask FixBot
  7. 2010-2015 Hyundai Elantra Head Lights Replacement: step 7, image 1 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 7, image 2 of 3 2010-2015 Hyundai Elantra Head Lights Replacement: step 7, image 3 of 3
    • Align the headlight assembly with the chassis and reconnect the power connector.
    • Reinsert and tighten the screws and bolt to secure the headlight in place.
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
Just used this guide for my car and it was super easy to follow! Didn’t even take 30 minutes to do.
EddyLainez - Reply Share
Past 24 Hours: 7
Past 7 Days: 78
Past 30 Days: 342
All Time: 2,877
