Shop the Holiday Gift Guide
2010-2017 Suzuki Swift Washer Fluid Pump Replacement
View statistics:
Past 24 Hours:
9
Past 7 Days:
51
Past 30 Days:
221
All Time:
497
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
There are several reasons why washer fluid does not appear when activating the washer functions on your console.
  • The washer fluid reservoir is empty.
  • There is an issue with the lines or the nozzles.
  • The washer fluid pump(s) are broken.
You can check if the pumps are not working by turning on the car accessories and switching on the washer fluid function for the windshield or the rear window. A working pump should make a high pitched whining sound which is audible from the front seat.
The washer fluid pumps have a separate fuse in the dashboard fuse box. Make sure to check that before proceeding to dismantle your car.
This guide will now show you how to replace the washer fluid pumps.
  • If you need to replace both pumps (or just the windshield washer fluid pump), disconnecting the reservoir is required.
  • If you only need to replace the rear window washer fluid pump, skip to step 15 after emptying the reservoir.
    1. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, disconnect the battery: step 1, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, disconnect the battery: step 1, image 2 of 2
      • Use the 10mm socket to disconnect the negative terminal first.
      • Disconnect the positive terminal next, also with the 10mm.
      Ask FixBot
    1. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove the top fasteners: step 2, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove the top fasteners: step 2, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove the top fasteners: step 2, image 3 of 3
      • Open the hood and unscrew the 10mm bolts located at the top.
      • Unscrew the screw located at the side top corner under the fender, repeat on the other side.
      Ask FixBot
    2. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove bottom fasteners: step 3, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove bottom fasteners: step 3, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove bottom fasteners: step 3, image 3 of 3
      • Unscrew 4 screws located underneath the front of the front bumper.
      • With the flathead, unclip the 2 push rivets underneath the side of the front bumper, disconnecting each fender from the bumper.
      • Repeat on the other side.
      Ask FixBot
    3. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, detach top corners: step 4, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, detach top corners: step 4, image 2 of 2
      • Gently, pull the side corner loose.
      • Pull from the car and slightly downwards to detach the remaining corner.
      Ask FixBot
    4. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, unlatch the bumper: step 5, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, unlatch the bumper: step 5, image 2 of 2
      • If your car has fog lights, make sure you disconnect them from the car's wiring.
      • The bumper is now only attached with 2 clips at the top.
      • Push the front of each clip towards the car and unlatch it.
      Ask FixBot
    5. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove the bumper: step 6, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove the bumper: step 6, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove the bumper: step 6, image 3 of 3
      • Hold the bumper in the center and remove it by moving it down and outwards.
      • The bumper wraps around the bottom and fender parts, take care not to damage anything when removing the bumper.
      • Some of the 4 bottom nut clips might move or detach entirely when removing the bumper. Ensure these are at their correct positions.
      Ask FixBot
    1. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, empty the reservoir: step 7, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, empty the reservoir: step 7, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, empty the reservoir: step 7, image 3 of 3
      • Put a bucket or tub underneath the reservoir.
      • Pull out the rear window washing fluid pump and let the reservoir drain into the tub.
      • Alternatively, use a fluid pump to drain the reservoir from the top.
      Ask FixBot
    2. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, unbolt the reservoir: step 8, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, unbolt the reservoir: step 8, image 2 of 2
      • If you only need to replace the rear window washer fluid pump, skip to step 15.
      • Unbolt the bottom reservoir bolt with the 10mm socket.
      • Unbolt the top rear reservoir bolt.
      • Leave the top front reservoir bolt for now.
      Ask FixBot
    3. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, undo the cable clips: step 9, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, undo the cable clips: step 9, image 2 of 2
      • Using the plyers, press the front cable clip from the bottom while pulling out the clip.
      • And repeat for the rear cable clip.
      Ask FixBot
    4. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, disconnect the reservoir: step 10, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, disconnect the reservoir: step 10, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, disconnect the reservoir: step 10, image 3 of 3
      • Pull out the filler neck.
      • Unscrew the last reservoir bolt and gently lower the reservoir.
      • Make sure you catch the remaining washer fluid.
      Ask FixBot
    5. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove windshield washer fluid pump: step 11, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove windshield washer fluid pump: step 11, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove windshield washer fluid pump: step 11, image 3 of 3
      • Remove the windshield washer fluid pump from the reservoir.
      • Disconnect the L hose connector from the pump.
      • Disconnect the electrical connector by lifting the clamp slightly with a screwdriver and pushing the connector off.
      Ask FixBot
    6. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, replace windhield washer fluid pump: step 12, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, replace windhield washer fluid pump: step 12, image 2 of 2
      • Replace the broken pump and reconnect the output hose and connector.
      • Push the pump back into the reservoir.
      Ask FixBot
    7. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, bolt the reservoir back: step 13, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, bolt the reservoir back: step 13, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, bolt the reservoir back: step 13, image 3 of 3
      • Place back the reservoir and fasten the top front bolt,
      • the bottom bolt, and
      • the top rear bolt.
      Ask FixBot
    8. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, attach cable clips and hose: step 14, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, attach cable clips and hose: step 14, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, attach cable clips and hose: step 14, image 3 of 3
      • Push the front cable clip back onto the reservoir.
      • Push the rear cable clip back onto the reservoir.
      • Push the windshield hose back onto the reservoir.
      Ask FixBot
    9. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove rear window washer fluid pump: step 15, image 1 of 2 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, remove rear window washer fluid pump: step 15, image 2 of 2
      Ask FixBot
    10. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, replace rear window washer fluid pump: step 16, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, replace rear window washer fluid pump: step 16, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, replace rear window washer fluid pump: step 16, image 3 of 3
      • Push the hose back onto the reservoir.
      Ask FixBot
    11. 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, fill the reservoir: step 17, image 1 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, fill the reservoir: step 17, image 2 of 3 2010-2017 Suzuki Swift Washer Fluid Pump Replacement, fill the reservoir: step 17, image 3 of 3
      • If you removed the filler neck, push it back into the reservoir.
      • Fill the reservoir, at least above the pump level.
      • Check for leaks.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order starting from step 6.
knipwim
16,454 Reputation
45 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 51
Past 30 Days: 221
All Time: 497
