Shop the Holiday Gift Guide
2010-2017 Suzuki Swift MAF Sensor Replacement
Views: 7K
View statistics:
Past 24 Hours:
20
Past 7 Days:
189
Past 30 Days:
790
All Time:
7,033
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The mass air flow sensor measures the amount of air entering the engine. When the MAF sensor does not work correctly, the engine computer miscalculates the amount of fuel for the engine leading to several possible driveability issues.
The sensor is located between the engine air filter and the intake manifold of the engine, on the backside of the air intake box.
This manual will show how to replace the MAF sensor through a disassembly of the air intake box.
    1. 2010-2017 Suzuki Swift MAF Sensor Replacement, disconnect the battery: step 1, image 1 of 2 2010-2017 Suzuki Swift MAF Sensor Replacement, disconnect the battery: step 1, image 2 of 2
      • Use the 10mm socket to disconnect the negative terminal first.
      • Disconnect the positive terminal next, also with the 10mm.
      Ask FixBot
    1. 2010-2017 Suzuki Swift MAF Sensor Replacement, Loosen the air intake box: step 2, image 1 of 3 2010-2017 Suzuki Swift MAF Sensor Replacement, Loosen the air intake box: step 2, image 2 of 3 2010-2017 Suzuki Swift MAF Sensor Replacement, Loosen the air intake box: step 2, image 3 of 3
      • Unscrew the 10mm bolts.
      • Remove the push rivet with the flathead.
      • Unclip the cable from the bracket. Use the plyers to press the lock from beneath and pull the clip loose.
      • Pull back the clasps connecting the air intake box to the rest of the intake system.
      Ask FixBot
    2. 2010-2017 Suzuki Swift MAF Sensor Replacement, Remove the air intake box: step 3, image 1 of 3 2010-2017 Suzuki Swift MAF Sensor Replacement, Remove the air intake box: step 3, image 2 of 3 2010-2017 Suzuki Swift MAF Sensor Replacement, Remove the air intake box: step 3, image 3 of 3
      • Grab the box at the left side and pull up and towards the right to pull the top part of air intake box out.
      • Pull the intake pipe up and out.
      Ask FixBot
    1. 2010-2017 Suzuki Swift MAF Sensor Replacement, Detach the fuel vapor canister purge valve solonoid: step 4, image 1 of 2 2010-2017 Suzuki Swift MAF Sensor Replacement, Detach the fuel vapor canister purge valve solonoid: step 4, image 2 of 2
      • Use the 10mm socket to unscrew the bolt attaching the purge valve solonoid to the airbox outlet.
      • Unclip the solonoid electrical cable from the airbox outlet. Use a screwdriver to press in the clip, while pulling from the other side.
      Ask FixBot
    2. 2010-2017 Suzuki Swift MAF Sensor Replacement, Unplug the MAF sensor: step 5, image 1 of 2 2010-2017 Suzuki Swift MAF Sensor Replacement, Unplug the MAF sensor: step 5, image 2 of 2
      • Push the yellow cable connector clip up.
      • Carefully pull out the cable connector from the sensor.
      Ask FixBot
    3. 2010-2017 Suzuki Swift MAF Sensor Replacement, Replace the MAF Sensor: step 6, image 1 of 3 2010-2017 Suzuki Swift MAF Sensor Replacement, Replace the MAF Sensor: step 6, image 2 of 3 2010-2017 Suzuki Swift MAF Sensor Replacement, Replace the MAF Sensor: step 6, image 3 of 3
      • With the 7mm socket, loosen the cable clamp holding the airbox outlet to the manifold intake hose.
      • Remove the airbox outlet from the engine bay.
      • With the Phillips screwdriver, undo the screws attaching the sensor to the airbox outlet.
      • Carefully pull out the sensor.
      Ask FixBot
Author
with
knipwim
16,454 Reputation
45 Guides authored
2 Guide Comments
hay que calibrar con scanner? luego de montar el sensor?
Hrodric Andrew - Reply Share
@hrodricandrew No estoy 100% seguro, pero no lo creo
knipwim - Reply Share
Past 24 Hours: 20
Past 7 Days: 189
Past 30 Days: 790
All Time: 7,033
