Shop the Holiday Gift Guide
2009 Subaru Impreza WRX Rear Door Panel Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
89
All Time:
3,184
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the rear door panel is necessary for replacing the rear door speaker. This guide will show you how to replace the rear door panel if it is broken, or simply how to remove the panel in order to access the speaker.
Tools
    1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: step 1, image 1 of 1
      • Pry off the plastic tab inside the rear door handle.
      Ask FixBot
    2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 2, image 1 of 1
      • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
      Ask FixBot
    3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 3, image 1 of 1
      • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
      Ask FixBot
    4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 4, image 1 of 1
      • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
      Ask FixBot
    5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 5, image 1 of 2 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 5, image 2 of 2
      • Use flathead to pry off the upper panel located at the top of the rear door panel.
      Ask FixBot
    6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 6, image 1 of 2 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 6, image 2 of 2
      • Use the flathead screwdriver to pry off and remove the panel over the door handle.
      Ask FixBot
    7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 7, image 1 of 1
      • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
      Ask FixBot
    8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 8, image 1 of 1
      • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
      Ask FixBot
    9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 9, image 1 of 1
      • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
      Ask FixBot
    10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 10, image 1 of 1
      • Use your hands to pull off and remove the door panel from the frame.
      Ask FixBot
    11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: step 11, image 1 of 1
      • Using your hands, remove the two remaining wires connecting the door panel to the frame.
      • The door panel is now completely removed from the frame.
      Ask FixBot
Author
with
Joseph Coplon
101 Reputation
1 Guide authored
Cal Poly, Team 8-3, Regan Spring 2015 Member of Cal Poly, Team 8-3, Regan Spring 2015
CPSU-REGAN-S15S8G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 89
All Time: 3,184
