2009 Honda Fit Brake Switch Stopper Replacement
  1. 2009 Honda Fit Brake Switch Stopper Replacement, Brake Switch Stopper: step 1, image 1 of 3 2009 Honda Fit Brake Switch Stopper Replacement, Brake Switch Stopper: step 1, image 2 of 3 2009 Honda Fit Brake Switch Stopper Replacement, Brake Switch Stopper: step 1, image 3 of 3
    • Remove the panel protecting the pedal system. It will be under the steering wheel just above the pedals.
    • Rotate the plastic latch a quarter turn clockwise.
    • The subsequent images show it locked and then unlocked
    Ask FixBot
  2. 2009 Honda Fit Brake Switch Stopper Replacement: step 2, image 1 of 2 2009 Honda Fit Brake Switch Stopper Replacement: step 2, image 2 of 2
    • The plastic cover will be hanging on by a friction clip on the right side.
    • Grab the piece with both hands and pull down and out on the panel.
    Ask FixBot
  3. 2009 Honda Fit Brake Switch Stopper Replacement: step 3, image 1 of 2 2009 Honda Fit Brake Switch Stopper Replacement: step 3, image 2 of 2
    • Check that you are in park with the handbrake engaged and start the car.
    • This allows for the brake pedal to be pushed easily with your hands.
    Ask FixBot
  4. 2009 Honda Fit Brake Switch Stopper Replacement: step 4, image 1 of 2 2009 Honda Fit Brake Switch Stopper Replacement: step 4, image 2 of 2
    • This piece is hard to remove (when not broken) so the example is kind of off, though where you see the red circle is where the replacement piece has to go.
    • Push in the brake so you can insert the stopper, using force to push the stopper in place.
    Ask FixBot
  5. 2009 Honda Fit Brake Switch Stopper Replacement: step 5, image 1 of 1
    • Make sure the brakes work and turn off properly.
    • Follow steps 1 and 2 in reverse.
    Ask FixBot
Theresa
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 113
All Time: 467
