Shop the Holiday Gift Guide
2008-2012 Buick Enclave Stereo Head Unit Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
92
All Time:
456
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to remove the factory stereo head unit for either replacement or in order to upgrade with an aftermarket head unit.
    1. 2008-2012 Buick Enclave Stereo Head Unit Replacement, Remove Trim + Climate Control: step 1, image 1 of 3 2008-2012 Buick Enclave Stereo Head Unit Replacement, Remove Trim + Climate Control: step 1, image 2 of 3 2008-2012 Buick Enclave Stereo Head Unit Replacement, Remove Trim + Climate Control: step 1, image 3 of 3
      • Use a plastic trim removal tool to release the clips holding the trim piece to the dashboard
      • Then, carefully pull the trim straight away from the dashboard and set it to the side
      • The climate control buttons are part of this trim piece and are attached with multiple wiring harnesses to the rest of the dashboard
      Ask FixBot
    2. 2008-2012 Buick Enclave Stereo Head Unit Replacement, Removing the Head Unit: step 2, image 1 of 3 2008-2012 Buick Enclave Stereo Head Unit Replacement, Removing the Head Unit: step 2, image 2 of 3 2008-2012 Buick Enclave Stereo Head Unit Replacement, Removing the Head Unit: step 2, image 3 of 3
      • Use a 7mm socket or nut driver to remove the 4 bolts securing the head unit
      • Then, carefully pull the head unit out from inside the dashboard.
      Ask FixBot
    3. 2008-2012 Buick Enclave Stereo Head Unit Replacement, Disconnect Wiring Harnesses: step 3, image 1 of 2 2008-2012 Buick Enclave Stereo Head Unit Replacement, Disconnect Wiring Harnesses: step 3, image 2 of 2
      • On the back of the head unit, release the 2 black connectors by pressing the button on top of the connector and carefully pulling the connectors away from the head unit
      Ask FixBot
    4. 2008-2012 Buick Enclave Stereo Head Unit Replacement, Disconnect Antenna: step 4, image 1 of 2 2008-2012 Buick Enclave Stereo Head Unit Replacement, Disconnect Antenna: step 4, image 2 of 2
      • To remove the antenna cable, grip the connector by the black plastic ring and carefully pull it away from the head unit
      Ask FixBot
At this point, you may replace the factory head unit or install an aftermarket one. To reassemble your dashboard, follow these instructions in reverse order.
Author
with
n3rdbug96
1,892 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 92
All Time: 456
