2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement
  1. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement, Passenger Side Door Checker: step 1, image 1 of 2 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement, Passenger Side Door Checker: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the screw from the interior door handle.
    • Caution: Avoid applying excessive force to prevent stripping the screw head.
    Ask FixBot
  2. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 2, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 2, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 2, image 3 of 3
    • Use a trim removal tool to pry off the trim piece on the armrest.
    • Caution: Insert the tool carefully to avoid damaging anything
    • Work slowly along the edges to release each clip evenly.
    Ask FixBot
  3. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 3, image 1 of 2 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 3, image 2 of 2
    • Use a Phillips screwdriver to remove the screws hidden under the armrest trim and at the bottom edge of the door panel.
    • Take note of the screw lengths to ensure proper placement during reassembly.
    Ask FixBot
  4. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 4, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 4, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 4, image 3 of 3
    • Carefully pull the door panel away from the door frame to release the clips. Start from the bottom and work your way around the edges.
    • Caution: Do not pull too hard to avoid breaking the plastic clips.
    • Listen for the sound of clips releasing to ensure all are detached.
    Ask FixBot
  5. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 5, image 1 of 2 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 5, image 2 of 2
    • Carefully disconnect the door from the interior mechanism.
    • Label the connectors if necessary to avoid confusion during reassembly.
    Ask FixBot
  6. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 6, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 6, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 6, image 3 of 3
    • Disconnect the lock cable carefully from the interior mechanism.
    Ask FixBot
  7. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 7, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 7, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 7, image 3 of 3
    • Gently unplug all electrical connectors, including those for the window and locking controls
    • Caution: Avoid pulling on the wires directly; press the release tabs on the connectors.
    Ask FixBot
  8. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 8, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 8, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 8, image 3 of 3
    • Use a ratchet to remove the screws securing the speaker to the door frame and carefully disconnect the speaker and set it aside.
    • Handle the speaker gently to avoid damaging its delicate components.
    • There is no need to disconnect the speaker; it can be placed carefully to the side.
    Ask FixBot
  9. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 9, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 9, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 9, image 3 of 3
    • Use a 10mm socket wrench to unbolt the door checker from the car door frame.
    • Support the door while unbolting to prevent it from shifting or sagging.
    • Keep the bolts with the old door checker for reference during installation.
    Ask FixBot
  10. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 10, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 10, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 10, image 3 of 3
    • Reach into the access hole in the door panel to grip the door checker. Carefully slide it out through the hole.
    • Caution: Be mindful of sharp edges inside the door panel to avoid injury.
    Ask FixBot
  11. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 11, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 11, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 11, image 3 of 3
    • Align the new door checker with the mounting holes inside the door frame. Carefully insert it through the access hole and ensure proper positioning.
    • Double-check the alignment of the door checker before bolting it in place.
    Ask FixBot
  12. 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 12, image 1 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 12, image 2 of 3 2006 Infiniti G35 Coupe Passenger Side Door Checker Replacement: step 12, image 3 of 3
    • Align the bolts in the holes, then use the 10mm socket wrench to bolt the new door checker securely to the frame.
    • Caution: Do not overtighten the bolts to avoid damaging the door checker or its mounting points.
    • Test the door at different angles to verify it holds open properly without popping noises.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure all electrical connections are securely reattached, and the door panel is properly aligned and fastened to avoid any loose components. Once completed, test the door to ensure the new door checker operates smoothly and holds the door in place without any issues. Congratulations on successfully replacing the door checker—your Infiniti G35 Coupe's door should now function perfectly!
Derreck Soriano
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 318
