Archived
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Archived
Introduction
The engine oil is used as a lubricant that prevents metal parts from rubbing together and overheating. Keeping your engine oil clean ensures a longer life for your vehicle.
  1. Identify the jack point, located directly underneath your car, in the center portion between the front two wheels. Place the Hydraulic Jack beneath the jack point.
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
  2. Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points. Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
  3. Identify the open hood latch. It is located to the left of your brake pedal. Pull latch toward you. You should hear a click from the front of the car.
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  4. Walk to the front of the car. Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood. Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  5. Pull out the dipstick Unscrew the cap from the oil tank
    • Pull out the dipstick
    • Unscrew the cap from the oil tank
    • Set both aside. lay a towel over the engine block and set dipstick and the cap on that to avoid traces of oil.
  6. Place oil pan  between the front tires Lay down and slide yourself headfirst under the front of the car. To the side of the right tire you will see the oil tank. Loosen the drain bolt with a 17mm wrench. Once loose, use your hand to unscrew the rest of the way.
    • Place oil pan between the front tires
    • Lay down and slide yourself headfirst under the front of the car. To the side of the right tire you will see the oil tank.
    • Loosen the drain bolt with a 17mm wrench. Once loose, use your hand to unscrew the rest of the way.
    • Once the bolt is removed, oil will pour out of the hole very quickly. Position the oil pan under the hole before completely removing the screw.
    • Allow oil to drain until the flow is reduced to a slow drip.
  7. Replace the crush washer on the drain bolt with a new one. Put the drain bolt back into the oil tank and tighten with 29 ft-lb of torque.
    • Replace the crush washer on the drain bolt with a new one.
    • Put the drain bolt back into the oil tank and tighten with 29 ft-lb of torque.
  8. Using a funnel, pour the new oil into the oil tank.
    • Using a funnel, pour the new oil into the oil tank.
    • Honda recommends using 4 quarts of their synthetic blend 5w-20 Motor oil.
  9. Put the dipstick back in. Put the oil tank cap back on. close the hood.
    • Put the dipstick back in.
    • Put the oil tank cap back on.
    • close the hood.
Finish Line
4 other people completed this guide.
Frank
267 Reputation
2 Guides authored
Cal Poly, Team 12-35, Maness Spring 2014 Member of Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Members
5 Guides authored
2 Comments
Thanks. I was never able to find the oil filter before. Note that the Honda owner's manual lists oil capacity at 4.5 quarts, whereas you say 4 quarts; I don't know if this makes a difference.
JMY - Reply
Well-done.
The only issue I have is that I don't have the tools.
The explanations are ok
Olayinka Erinfolami - Reply
Past 24 Hours: 11
Past 7 Days: 65
Past 30 Days: 346
All Time: 37,437
