Introduction
The following procedure is correct for all Duratec engines in the Ford Focus, including the 2.3L engine in 2004-2007 models. As stated on the oil filler cap, use 5W-20 oil when adding or changing oil. There are a number of different oil filters by different manufacturers that will work for the Focus, so you may want to consult the parts counter at your local auto parts store.
Convention has always been to change oil at 3,000 mile intervals, but modern oil and oil filters allow for much more time between changes. As long as you check your oil level regularly, you can easily make it 5,000 miles with conventional oil, and over 7,500 miles with synthetic oil.
Remove the oil filler cap by rotating it 1/4 turn counterclockwise and lifting it off the valve cover.
Locate the oil pan drain plug underneath the car. It is a 13 mm hex bolt that faces towards the rear of the car.
Place an oil drain pan underneath the oil pan to catch the draining oil. Remember to place it towards the rear of the car, since the oil will come out of the oil pan in a stream.
Loosen the oil pan drain plug with a 13 mm socket wrench until it comes off and oil is draining out of the oil pan.
My 2006 ford focus sedan uses a size 14mm socket, not a size 13mm. I just got finished changing my oil yesterday and I had to use a size 14mm socket to fit my plug bolt. Make sure what Size socket your Ford focus actually uses so that you gace the correct size socket before you start your oil change. It's better to check the correct size before you get started so you don't have to back track searching for the correct size. I don't know if my oil pan bolt has been modified in some way or not. I just know I had to use a 14mm socket
Place a funnel in the oil fill hole in the valve cover.
Pour a quart of oil into the funnel and let all of it drain and collect in the oil drain pan.
Wipe off and replace the oil pan drain plug. Use a moderate amount of force, but do not over-tighten the bolt.
Position the oil drain pan underneath the oil filter.
Turn the oil filter counterclockwise (when looking up at it) to remove it.
Set the old filter in your oil drain pan with the gasket facing down to allow the oil to drain out of it.
Let the rest of the oil from the engine drain and collect in the oil drain pan.
Once the oil filter is removed carefully inspect the old filter and the filter seating surface on the engine for the gasket from the old filter. Sometimes this will remain in place and is a guaranteed major leak if not removed prior to installing the new filter.
My ex didn't check the old oil filter on my car and the o ring was left there, put on the new oil filter and blew my engine the next day. Always check!
Apply a small amount of clean oil to the rubber gasket on the new oil filter.
Wipe off the oil filter mounting spot and install the new filter by rotating it clockwise until you cannot tighten it anymore.
Pour five quarts of 5W-20 oil into a funnel in the oil fill hole.
Reinstall the oil filler cap by turning it 1/4 turn clockwise.
Start your car and let it run. Check for leaking oil underneath the car. If you notice any leaks, tighten the drain plug, being careful not to over-tighten it and crack the oil pan.
Close the hood and lower the car back to the ground: you're done!
Allow 12-24 hours for all of the oil to drain out of the old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
Wow! I feel like I'd rather change my oil than pay someone $20-30 to do
I paid $19 for 5 quart's of motor craft OEM 5-20w oil blend . At Walmart. No need to waste money on full synthetic. Your came from the factory with Motor craft 5-20w blend for a reason. Also bought a filter for under $4. In my area It cost over $60 at those oil change places for a oil blend with no say in what brand oil. U will have great satisfaction in doing the job yourself. Wear vinyl or nitrate gloves. Used oil is expecially toxic. P.S. always put news paper or painters disposable tarp cut to size. Under your drain pan. Expecially your first time u are bound to spill some of the old oil. Have fu
fordnut? -
I tighten oil filters by hand, and go as tight as I can. Some will say it’s not tight enough but if you have strong arms and hands it’s plenty tight, but not too tight as my gloves inevitability have a tiny residue on from removing the old filter. Never had a problem in 20 years. If you use a wrench, as said seat the filter gasket hand-snug then no more than 3/4 turn.
37 other people completed this guide.
14 Comments
Excelente aporte David. Muy útil la información para realizarlo de una manera eficiante.
Saludos
My 07 ford focus ses has just surpassed the 300, 000 klm mark. Only idem I've had to replace is the alternator in the past year.
Car is still running flawlessly. Iam shooting
For 500,000 klms. Think I'll make it?
How’s the car lasting?
How's she running?
I just passed 217000
As rcics -
Great instructional presentation. Thanks a lot.
Capt. Michael B. Cuanzon
1. Forgot to mention to park vehicle on level ground, turn off engine, wait at least 5 minutes & then check oil level.
2. The car engine roughly takes only 4 ½ quarts (4.3 L) of motor oil, With oil filter change. [otherwise you overfilled it.]
Could you please inform me is it possible to use in Ford Focus 2005 auto SL SX sedan the following oils:
5 l Valvoline SAE20W-50 API SG/CD
5l Valvoline Engine Armour Synthetic Blend for 15W-40 Motor oil
WOW! OUTSTANDING tutorial.
This is well done, but why pour the extra quart in a non running engine? It wont touch anything except the bottom of the oil pan. It wont flush the oil gallerys, or anywhere the oil pump is designed to take the oil. I csn see using a flushing compound with the old oil and letting the engine run for a few minutes to flush it, but what does pouring oil in a non running engine do? If i am missing something please reply and let me know. I am admittedly not a mechanic, just wondering how this might work.
Hahaha he forgot to tell you people how to reset the oil indicater light cause if you keep driving it after an oil change or two it will come on. He forgot to mention that you have to put the ignition to the on position and to hold down the gas and brake pedal at the same time for roughly 20 seconds. Hope I could help.
How do you change a diesel motors oil filter 1.8 ford banana utility 2006.
junejimmy3 - Reply
How do you fit a new oil filter to a ford bantam1.8 diesel utility van 2006
junejimmy3 - Reply
How do you fit a new oil filter to a 2006 ford banana 1.8 diesel utility van
junejimmy3 - Reply
