2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly
  1. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, Stereo Unit: step 1, image 1 of 1
    • This is the front panel of the 2004 Mazda 3 Stereo-CD Player. It's listed under the model number: BN85-66-9RXA.
  2. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 2, image 1 of 1
    • On the right side of the unit, designated by the letter R, remove 6 screws using a Phillips #2 screwdriver.
  3. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 3, image 1 of 1
    • On the left side of unit, designated by the letter L, remove 6 screws using a Phillips #2 screwdriver.
    • Gently pull on the cable to disconnect it from the front panel.
    • Now you can fully detach the front panel as well as the LCD display from the unit.
  4. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 4, image 1 of 1
    • On the top of the unit, remove 2 screws with a Phillips #2 screwdriver.
    • Lift and remove the top case from the unit.
  5. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 5, image 1 of 1
    • On the bottom of the unit, remove 2 screws with the Phillips #2 screwdriver.
  6. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 6, image 1 of 1
    • On the back of the unit, remove 8 screws with a Phillips #2 screwdriver.
    • Remove 1 screw with a Phillips #1 screwdriver.
    • Pull off both the bottom and top metal plates.
  7. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 7, image 1 of 1
    • On the front of the unit, remove 4 screws with a Phillips #2 screwdriver.
  8. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 8, image 1 of 1
    • On the left side of the unit, designated by the letter L, remove 2 screws with a Phillips #2 screwdriver.
  9. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 9, image 1 of 1
    • On the right side of the unit, designated by the letter R, remove 2 screws with a Phillips #2 screwdriver.
    • Pull the front metal plate off the unit. Then lift the CD drive from the lower metal case.
  10. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, CD Drive: step 10, image 1 of 1
    • Remove 2 screws with a Phillips #1 screwdriver from the front of the CD drive.
    • Very gently pull apart the top metal case from the CD drive without damaging the ribbon cable.
  11. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: step 11, image 1 of 1
    • Gently pull the ribbon cable from the connector on the CD drive logic board.
2 other people completed this guide.
Robin Nystrom
182 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 39
All Time: 4,985
