Introduction
Use this guide to replace the Windshield Washer Nozzles on your 2004-2012 Nissan Versa. Nozzles can fail due to normal wear and tear or be physically damaged. Symptoms of a bad Windshield Washer Nozzle include fluid leaks around the nozzle, inconsistent washer fluid spray, and visible damage to the nozzle.
WARNING! WHILE OPERATING AT DRIVER'S SIDE: When removing the nozzle, do not release the hose. If it falls into the hole, it could be very difficult to retrieve. Make sure you have the replacement nozzle at hand.
Lift up the windshield wiper arm to work comfortably.
Insert the flat end of a spudger in the bottom of the nozzle and push, just a little.
First, set the cloth around the hose.
Next, pour the hot water over the cloth. Do not harm yourself!
Special thanks to these translators:
100%
Gianfranco Sergi is helping us fix the world! Want to contribute?
Start translating ›
