2003-2007 Honda Accord Third Brake Light Replacement
    1. 2003-2007 Honda Accord Third Brake Light Replacement, Third Brake Light: step 1, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement, Third Brake Light: step 1, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement, Third Brake Light: step 1, image 3 of 3
      • Pull the trunk lever inside the car located near the bottom left of the driver's seat to open the trunk.
      • This will grant you access to the trunk interior to start step 2.
      Ask FixBot
    2. 2003-2007 Honda Accord Third Brake Light Replacement: step 2, image 1 of 2 2003-2007 Honda Accord Third Brake Light Replacement: step 2, image 2 of 2
      • Take notice of where the brake light connection is.
      Ask FixBot
    3. 2003-2007 Honda Accord Third Brake Light Replacement: step 3, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 3, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 3, image 3 of 3
      • Find the connector, pinch both sides and pull apart to unplug the connector.
      Ask FixBot
    4. 2003-2007 Honda Accord Third Brake Light Replacement: step 4, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 4, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 4, image 3 of 3
      • Attach the 8mm socket to the ratchet and loosen each bolt by twisting the ratchet in a counterclockwise direction.
      Ask FixBot
    5. 2003-2007 Honda Accord Third Brake Light Replacement: step 5, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 5, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 5, image 3 of 3
      • Once all the nuts are removed from the bolts of the brake light, remove the old brake light with a small flathead screwdriver.
      • When using a flathead screwdriver, be careful not to poke yourself.
      Ask FixBot
    6. 2003-2007 Honda Accord Third Brake Light Replacement: step 6, image 1 of 1
      • Clean off the remaining old seal.
      • You can use wet wipes, paper towels, or any cleaning devices of your liking.
      Ask FixBot
    7. 2003-2007 Honda Accord Third Brake Light Replacement: step 7, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 7, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 7, image 3 of 3
      • Take the new brake light and insert the brake plug into the location of your old brake light.
      Ask FixBot
    8. 2003-2007 Honda Accord Third Brake Light Replacement: step 8, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 8, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 8, image 3 of 3
      • Use your ratchet wrench to screw the nuts onto the bolts of the new brake light.
      Ask FixBot
    9. 2003-2007 Honda Accord Third Brake Light Replacement: step 9, image 1 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 9, image 2 of 3 2003-2007 Honda Accord Third Brake Light Replacement: step 9, image 3 of 3
      • Connect the new brake light plug to the power connection.
      Ask FixBot
    10. 2003-2007 Honda Accord Third Brake Light Replacement: step 10, image 1 of 2 2003-2007 Honda Accord Third Brake Light Replacement: step 10, image 2 of 2
      • Check to ensure brake works.
      Ask FixBot
Finish Line
Shoshana Greenspan
181 Reputation
1 Guide authored
UC Davis, Team 1-2, Whithaus Spring 2026 Member of UC Davis, Team 1-2, Whithaus Spring 2026
UCD-WHITHAUS-S26S1G2
4 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 56
All Time: 124
