2003-2007 Honda Accord Battery Replacement
  1. 2003-2007 Honda Accord Battery Replacement, Battery: step 1, image 1 of 2 2003-2007 Honda Accord Battery Replacement, Battery: step 1, image 2 of 2
    • Locate the latch to open your hood, normally located by your left foot when sitting in the driver's seat.
    • After lifting the latch, open your hood and securely hold it up.
  2. 2003-2007 Honda Accord Battery Replacement: step 2, image 1 of 3 2003-2007 Honda Accord Battery Replacement: step 2, image 2 of 3 2003-2007 Honda Accord Battery Replacement: step 2, image 3 of 3
    • You will lose your radio station presets and clock time if you do not use a Memory Saver. One will NOT be used in this guide.
    • The battery is located on the front driver's side of the vehicle.
    • Begin using your ratchet to loosen and remove the negative (black) cable from the terminal.
    • You can use a rag or towel to cover the cable in order to prevent a short.
  3. 2003-2007 Honda Accord Battery Replacement: step 3, image 1 of 2 2003-2007 Honda Accord Battery Replacement: step 3, image 2 of 2
    • Loosen and remove the positive (Red) cable from the terminal.
  4. 2003-2007 Honda Accord Battery Replacement: step 4, image 1 of 3 2003-2007 Honda Accord Battery Replacement: step 4, image 2 of 3 2003-2007 Honda Accord Battery Replacement: step 4, image 3 of 3
    • Remove the cross-bar that holds the battery in place by loosening both bolts.
    • Lift out the bracket.
  5. 2003-2007 Honda Accord Battery Replacement: step 5, image 1 of 1
    • Remove the battery by lifting it straight up and out.
    • Avoid tilting the battery in order to prevent an acid spill.
  6. 2003-2007 Honda Accord Battery Replacement: step 6, image 1 of 1
    • Replace with a new battery.
    • Secure the battery cover back in place.
  7. 2003-2007 Honda Accord Battery Replacement: step 7, image 1 of 1
    • Place the cross-bar back in place.
    • When placing the cross-bar back in, make sure the bars are properly hooked into place.
  8. 2003-2007 Honda Accord Battery Replacement: step 8, image 1 of 3 2003-2007 Honda Accord Battery Replacement: step 8, image 2 of 3 2003-2007 Honda Accord Battery Replacement: step 8, image 3 of 3
    • Repeat the steps in reverse order to properly secure battery.
  9. 2003-2007 Honda Accord Battery Replacement: step 9, image 1 of 1
    • Start your car in order to make sure all of your electronic components are working properly.
Johnny Hernandez
371 Reputation
1 Guide authored
Cal Poly, Team 15-4, Green Fall 2015 Member of Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 Members
4 Guides authored
Past 24 Hours: 10
Past 7 Days: 42
Past 30 Days: 249
All Time: 61,916
