2003-2008 Toyota Corolla Headlight Bulb Replacement
  1. 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 2 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: step 1, image 2 of 2
    • Locate the handle to open the hood. It will be on the driver side of the car to the left.
    • Pull up on the handle and the hood should pop open a small amount.
  2. 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 2, image 1 of 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 2, image 2 of 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 2, image 3 of 3
    • Reach under the hood in the front where there is a small notch and pull the latch up. This will allow the hood to open all the way.
    • Locate the prop and insert it into the hole in the hood.
  3. 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 3, image 1 of 1
    • Locate the bulb. It will be in the front and to the side. Start with the side opposite from the battery.
  4. 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 4, image 1 of 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 4, image 2 of 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 4, image 3 of 3
    • Twist assembly 45 degrees counter clockwise and pull straight out.
    • Be careful not to touch the glass on the new bulb. The oils from your hand could cause premature bulb failure.
  5. 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 5, image 1 of 2 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 5, image 2 of 2
    • Lift up on the latch and pull. The bulb will come free from the wires.
  6. 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 6, image 1 of 2 2003-2008 Toyota Corolla Headlight Bulb Replacement: step 6, image 2 of 2
    • Locate the other bulb, and repeat steps 3-5 to remove it.
10 other people completed this guide.
Frederick Henderson
389 Reputation
1 Guide authored
Cal Poly, Team 17-4, Green Fall 2015 Member of Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Members
4 Guides authored
One Comment
https://youtu.be/GHezj9nmbxE
Change headlight on your corolla in under one minute. So easy.
baxta777 - Reply
Past 24 Hours: 7
Past 7 Days: 95
Past 30 Days: 432
All Time: 91,698
