2002-2006 Acura RSX Fog Light Bulbs Replacement
  1. 2002-2006 Acura RSX Fog Light Bulbs Replacement, Fog Light Bulbs: step 1, image 1 of 2 2002-2006 Acura RSX Fog Light Bulbs Replacement, Fog Light Bulbs: step 1, image 2 of 2
    • Turn your steering wheel in the opposite direction of the fog light. (Ex: If you are working on the left fog light, turn your wheel in the right direction)
    Ask FixBot
  2. 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 2, image 1 of 3 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 2, image 2 of 3 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 2, image 3 of 3
    • Locate the connector to the fog light bulb. (shown in the picture)
    • The connector itself will have two tabs on each side. Firmly pry on both tabs and simultaneously pull the connector towards yourself.
    • The last picture is a reference of the connector you will need to disconnect.
    Ask FixBot
  3. 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 3, image 1 of 2 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 3, image 2 of 2
    • Rotate the fog light bulb clockwise to unhook the bulb out of its socket.
    • Once rotated, be careful not to drop the bulb, as rotating the bulb unhinges it from its socket
    Ask FixBot
  4. 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 4, image 1 of 2 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 4, image 2 of 2
    • Align the new bulb in the socket and turn it counterclockwise to secure. The new bulb will now sit in its socket and hold itself in place.
    • Grab your connector and make sure to connect it to the back of the new bulb.
    • The new replacement seen in this picture is an LED bulb, not a traditional light bulb, but the steps continue to be the same.
    Ask FixBot
  5. 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 5, image 1 of 2 2002-2006 Acura RSX Fog Light Bulbs Replacement: step 5, image 2 of 2
    • Turn on your fog lights to make sure they work.
    • Make sure the bulb is secure in place.
    Ask FixBot
Finish Line
Julius Marcoviche
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 99
