Introduction
Use this guide to replace the radiator in your 2001-2004 Toyota Sequoia. This process should be very similar for other cars featuring the 2UZ-FE 4.7 L V8 engine, such as the 2000-2004 Toyota Tundra.
Use a 10 mm socket to loosen the nut securing the negative battery terminal.
Pull the negative terminal up and away from the battery.
Use a pair and pliers to pinch and pull back the two clamps securing the transmission cooler hoses to the radiator.
Use a pair and pliers to pinch and pull back the clamp securing the lower radiator hose on the back of the lower left side of the radiator.
Disconnect the three hoses from the radiator.
To reinstall the radiator, follow these instructions in reverse order. Then fill the radiator with 14.3 quarts of Toyota Red antifreeze coolant.
3 other people completed this guide.
