1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement
  1. 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 3 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement, Headlight Bulb: step 1, image 2 of 3 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement, Headlight Bulb: step 1, image 3 of 3
    • Here is a 2000 Jeep Grand Cherokee with a burned out driver side headlight bulb.
    • Open the hood. On top of the affected headlight assembly is a single 7mm hex bolt.
    • Remove the bolt
  2. 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 2, image 1 of 3 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 2, image 2 of 3 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 2, image 3 of 3
    • Remove the bolt. It is approximately 6 inches long.
    • Grab the headlight assembly on the fender side,
    • as well as the grill side.
  3. 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 3, image 1 of 3 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 3, image 2 of 3 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 3, image 3 of 3
    • Then pull the assembly straight out
    • The light bulbs will now be accessible.
    • Remove the bulb by twisting it in a counter clockwise direction, then pulling it out of the headlight assembly.
  4. 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 4, image 1 of 2 1999-2004 Jeep Grand Cherokee Headlight Bulb Replacement: step 4, image 2 of 2
    • Use a flathead screwdriver (or similar tool) to lift the socket clip of the tab on the bulb and remove the bulb.
    • Change the bulb and the result will be fully functional headlights.
To reassemble your headlight, follow these instructions in reverse order.
18 other people completed this guide.
oldturkey03
781,527 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
32 Members
531 Guides authored
11 Comments
guide made this an ABC REPLACEMENT
jamesparker1948 - Reply
Easy peasy. Thanks!
panther2360 - Reply
On my 2001 Jeep Grand Cherokee Limited, there was an extra screw that needed to be removed. I didn't notice it and, in trying to remove the headlight housing, broke the plastic housing that was held in place by that screw.
Steven Adams - Reply
You didn't notice it? I wouldn't have you working on my car if you're that careless.
FixIt -
Justin answer the question we don't want to hear rude comments just the answer geeh dude so abrasive to ppl. C wats up wit that
Sheila'Thompson -
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 80
All Time: 87,200
