1997 Toyota Camry Stop and Tail Light Bulbs Replacement
  1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: step 1, image 1 of 3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: step 1, image 2 of 3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: step 1, image 3 of 3
    • Open the trunk.
    • Loosen three 15 mm screws using a Phillips #1 screwdriver.
    • Pull the cover clips at the base to remove.
    • Potential for device damage: Do not pull the cover clips prior to unscrewing as the cover clips can break.
    • Remove the cover by folding the cover backwards to expose the bulb assembly.
  2. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 2, image 1 of 2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 2, image 2 of 2
    • Grab the inner light bulb assembly using your thumb and forefinger.
    • Rotate the bulb assembly a quarter turn counterclockwise.
    • Pull it straight outwards until the bulb is displayed.
  3. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 3, image 1 of 1
    • While holding the assembly, grab the base of the light bulb with your thumb and forefinger.
    • Pull the bulb away from the assembly until it detaches. Discard the old bulb.
  4. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 4, image 1 of 1
    • Grab the new inner tail light bulb 3157 and push it into the bulb assembly.
    • Insert the bulb assembly straight into the socket. Rotate it a quarter turn clockwise to secure it.
  5. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 5, image 1 of 1
    • Repeat this process with the outer light bulb assembly using bulb 904.
  6. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 6, image 1 of 2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: step 6, image 2 of 2
    • Unfold the cover and place it back over the bulb sockets. Push the three cover clips into their sockets .
    • Screw the three 15 mm screws in with Phillips #1 screwdriver to secure the cover.
Ivan Navas
138 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 50
All Time: 2,206
