1986-1993 Volvo 240 Wheel Adapters Replacement
  1. 1986-1993 Volvo 240 Wheel Adapters Replacement, Front Wheels: step 1, image 1 of 3 1986-1993 Volvo 240 Wheel Adapters Replacement, Front Wheels: step 1, image 2 of 3 1986-1993 Volvo 240 Wheel Adapters Replacement, Front Wheels: step 1, image 3 of 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Wheel Adapters Replacement, Wheel Adapters: step 2, image 1 of 2 1986-1993 Volvo 240 Wheel Adapters Replacement, Wheel Adapters: step 2, image 2 of 2
    • Place the wheel adapter over the existing wheel lugs, then install and hand-tighten the provided lug nuts.
    • Tighten the lug nuts to 85 ft-lbs with a torque wrench or impact gun.
    • The choice is yours as to what adapters you'd like to install. We chose 5x4.75 adapters so that we could equip our Volvo 240 with C4 Corvette wheels!
    Hai bro..what's the suit thickness of the adapter for 240
    anas - Reply
  3. 1986-1993 Volvo 240 Wheel Adapters Replacement: step 3, image 1 of 1
    • Install your new wheels over the lugs of the wheel adapters and tighten the lug nuts to 85 ft-lbs.
Finish Line
2 other people completed this guide.
David Hodson
150,500 Reputation
127 Guides authored
2 Comments
Can I ask what adapters you're running and what modifications did you make to the front for the salad shooters I'm doing the EXACT same adapting and we can't fit the 16x8.5 wheel on the front
will davis - Reply
What was the thickness of the spacers?
K P - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 31
All Time: 8,636
