Shop the Holiday Gift Guide
1986-1993 Volvo 240 Manual Transmission Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
40
Past 30 Days:
139
All Time:
4,486
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. 1986-1993 Volvo 240 Manual Transmission Replacement, Manual Transmission: step 1, image 1 of 2 1986-1993 Volvo 240 Manual Transmission Replacement, Manual Transmission: step 1, image 2 of 2
      • Lift the bottom of the shift boot to expose the shifting socket.
      • Use snap ring pliers to remove the circlip securing the shifter to its socket.
      Ask FixBot
    2. 1986-1993 Volvo 240 Manual Transmission Replacement: step 2, image 1 of 2 1986-1993 Volvo 240 Manual Transmission Replacement: step 2, image 2 of 2
      • Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever.
      • Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
      • If the pin won't readily come free, try jiggling the shifter while you pull the pin.
      Ask FixBot
    3. 1986-1993 Volvo 240 Manual Transmission Replacement: step 3, image 1 of 2 1986-1993 Volvo 240 Manual Transmission Replacement: step 3, image 2 of 2
      • Remove the shift lever by pulling it straight up.
      • Remove the plastic bushing in the bottom of the shifter socket.
      Ask FixBot
    4. 1986-1993 Volvo 240 Manual Transmission Replacement: step 4, image 1 of 1
      • Remove the 6 nuts and bolts securing the drive shaft to the guibo and the back side of the transmission.
      • Only four nuts and bolts are visible and marked in the first picture. The others are hidden on the other side of the drive shaft.
      • Take note of how the bolts, washers and guibo are positioned. They are required to go back in the same way.
      Ask FixBot
    5. 1986-1993 Volvo 240 Manual Transmission Replacement: step 5, image 1 of 3 1986-1993 Volvo 240 Manual Transmission Replacement: step 5, image 2 of 3 1986-1993 Volvo 240 Manual Transmission Replacement: step 5, image 3 of 3
      • Support the drive shaft with a jack, jack stand, or other prop so it does not fall and get damaged or injure someone when the support is removed.
      • Remove the 4 bolts securing the drive shaft support.
      • Do not lose the washers on the 4 bolts or the spring and washer on the opposite side of the support.
      • Slowly lower the drive shaft and separate it from the transmission.
      • Remove the guibo and metal separator plate.
      • The separator may not come out with drive line and will be in the transmission.
      Ask FixBot
    6. 1986-1993 Volvo 240 Manual Transmission Replacement: step 6, image 1 of 3 1986-1993 Volvo 240 Manual Transmission Replacement: step 6, image 2 of 3 1986-1993 Volvo 240 Manual Transmission Replacement: step 6, image 3 of 3
      • Remove the bolts securing the transmission to the engine and to the starter.
      • Support the transmission so it doesn't fall when the final support is removed.
      • Generally, a jack is recommended for this.
      • Remove the four bolts securing the transmission support to the chassis.
      • Lower the transmission out of the car.
      • In many instances, the transmission may not come free from the engine once the bolts are removed. If this is the case, a pry bar is recommended to help separate the two.
      Ask FixBot
Author
with
Phillip Takahashi
88,138 Reputation
87 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 139
All Time: 4,486
